How to display Live streaming?
Now I have finished the decoding thread and finished the debugging.
The following is a part of my project :
decoder chain like this:
UDP recv--->rtp unpack---> vcu dec, and then  get the AL_TBuffer *pDisplayedFrame which holds the yuv BUFFER.
you can see that the screenshot is 14000+ frames of decoder, can run stably .
All right, now I'm more concerned if there's an example of an upper-level application code for me, and I can add the Display functionality to it.
I need Display Example Code, like exe_decoder in vcu_ctrl_sw
best wishes!
Tags (2)
Re: How to display Live streaming?
Xilinx uses the Linux DRM KMS Framework, so you could look at code like modetest from libdrm.  You could also look at the video_cmd that is part of the HDMI Frame Buffer Example design.
You might also want to consider using a higher level API like GStreamer.
Chris
Video Design Hub | Embedded SW Support
Chris
Thanks for your help!
I'm working on X11 server to do Display.
