How to set frame rate in VDMA
Hi Folks,
I am using VDMA for read and write to DDR3.
I am sending the image data from image sensor 4 frames per second, in this case how to handle the data in VDMA.
I need known how to configure the VDMA for frame rate.
Please suggest me regarding this.
Thanks and Best Regards
Vinod Sajjan
Tags (2)
Scholar u4223374
Re: How to set frame rate in VDMA
The VDMA doesn't need to know anything about framerate. Framerate is set by the camera; most cameras just output data at whatever speed they want to with no back-pressure (ie the VDMA block has no way to adjust the speed of the camera).
Hi @u4223374,
Thank you for your replay.
Okay.
But I have doubts.
->If, I write the data into DDR3 through VDMA only one time means how many time VDMA reads the data from DDR3?.
-> It is possible to make DDR3 read operation event base through VDMA?, means If only one time  write data to DDR3 through VDMA  than only one time i have to read.(1 write means 1 read).
please suggest me regards these doubts please do needful.
Vinod Sajjan
