Visitor sghaiera
HwCosim Error AccelDSP10.1
When I run the HwCosim Generation it gives me this error, any advise on how to solve the problem
ERROR:TclTasksC - ERROR:TclTasksC:project_028 - project set : Unknown property
   value "xc2v2000"
   Type [project properties] for more information.
ERROR: An error occurred when creating the ISE project.
Failed to execute command "project set device xc2v2000".
ERROR:TclTasksC:project_030 - project set: Cannot set "Device=xc2v2000"
Re: HwCosim Error AccelDSP10.1
Please make sure you can target this device in ISE standalone.  If this device is not available in ISE it will not be available from AccelDSP.
If you've confirmed that you can target a Virtex-II 2000 in ISE and you still get this error you can try running xlupdatepartinfo at the MATLAB promt and try again.  If it fails again with this message please create a WebCase with Xilinx support for further assistance:
http://www.xilinx.com/support/clearexpress/websupport.htm
Visitor sghaiera
What I get after executing the command is this warning "The following devices are not installed but ar ein the allowed list"
Any suggestion.
