I don't understand the output from the Complex Multiplier
Accepted Solution Solved
Accepted Solution
I have the complex multiplier IP (v6.0 with Vivado 2014.2) set up to have Operand A at 16-bits and Operand B at 17-bits. I was having trouble rounding and truncating to get the desired output where I wanted so I ran the core without rounding at full precision, which is 33-bits. I then tested the multiplier with different operand values to see what it was doing but got unexpected results.
For example:
Op A (16-bits) : 0x 1234
Op B (17-bits): 0x 0_2233
The expected output was (33-bits) : 0x 0_026E_885C
But my multiplier output gave (33-bits): 0x 0_0137_442E
If you look at this it means the result is shifted down by 1-bit, which almost certainly is wrong no matter how you round or truncate. Fortunately I am only interested in the upper portion of the output so I can truncate to get the result I want, even if I don't understand why I need to truncate to the number of bits I have to. I was careful to pick an easy example that doesn't push the limits of either operand, or the output, and uses all positive number to avoid complications form having signed operands.
What is going on here?
Instructor
Re: I don't understand the output from the Complex Multiplier
OK.  I think I see the reason for 34 bits.  The imaginary part of the result would need 34 bits for the worst case of all inputs being maximum negative value.  However the real part of the result would fit in 33 bits regardless of the inputs.  I guess the core is built to have symmetry in the result size.
-- Gabor
All Replies
Instructor
I looked at this in 2017.1 and got the same results with the same settings.  Interestingly, the output width box in the "Customize IP" window shows valid range of 2 to 34 bits.  I used the default of 33 bits, but perhaps you need to set it to 34 to avoid the scaling issue.
-- Gabor
Instructor
OK.  I tried with output width of 34 bits and got the correct result, 0x26e885c.  Now that I think of it, it makes sense that the result could grow by 1 bit because of the imaginary contribution to the result.  However I still haven't convinced myself that a signed result would need 34 bits.  In any case you need to select 34 bits to avoid truncation.
-- Gabor
Instructor
-- Gabor
Ah, brilliant! Well 2014.2 only gives a valid output range of 2-33 bits, it goes red if I try to input 34. But, I think you're right that the imaginary part could lead to another 1-bit growth. It's a complex multiplier so it should do 4 multiplies and then add the two pairs of products to gives the real and imaginary outputs. This add will cause the 1-bit growth. In my case one of my operand is real and the other imaginary so my test case did not account for this...
I guess this was an oversight in Vivado that was corrected later. Annoyingly I am due to upgrade to 2017.1 next week so I will have to wait util then to do it properly. Thanks for your input..
