Issue in enabling logo layer in video mixer ip.
We are trying to implement PIP using video mixer ip. In video mixer we have used 3 layers.
1 for video stream.
2 for memory layer.
3 for logo layer.
Board name :- Picozed-7030
Software version :- vivado 2018.2
            While testing we are able to see 1st layer i.e video stream. But now we want to configure 3 rd layer i.e logo layer. for this we are using following reference design(XAPP1291) files :
https://www.xilinx.com/support/documentation/application_notes/xapp1291-video-subsystem.pdf
In sdk when we call load logo layer function(XVMix_LoadLogo), it gets stucked in height-width loop. Because of this we couldn't able to go further and see anything over display.
snippet from file (xv_mix_l2.c):
int XVMix_LoadLogo(XV_Mix_l2 *InstancePtr,
XVidC_VideoWindow *Win,
u8 *RBuffer,
u8 *GBuffer,
u8 *BBuffer)
XV_mix *MixPtr;
u32 x,y;
u32 Rword, Gword, Bword;
u32 Width, Height;
u32 RBaseAddr, GBaseAddr, BBaseAddr;
int Status = XST_FAILURE;
Xil_AssertNonvoid(InstancePtr != NULL);
Xil_AssertNonvoid(RBuffer != NULL);
Xil_AssertNonvoid(GBuffer != NULL);
Xil_AssertNonvoid(BBuffer != NULL);
Xil_AssertNonvoid((Win->Width > (XVMIX_MIN_LOGO_WIDTH-1)) &&
(Win->Width <= InstancePtr->Mix.Config.MaxLogoWidth));
Xil_AssertNonvoid((Win->Height > (XVMIX_MIN_LOGO_HEIGHT-1)) &&
(Win->Height <= InstancePtr->Mix.Config.MaxLogoHeight));
Xil_AssertNonvoid((Win->StartX % InstancePtr->Mix.Config.PixPerClk) == 0);
Xil_AssertNonvoid((Win->Width % InstancePtr->Mix.Config.PixPerClk) == 0);
if(XVMix_IsLogoEnabled(InstancePtr)) {
MixPtr = &InstancePtr->Mix;
Width = Win->Width;
Height = Win->Height;
RBaseAddr = XV_MIX_CTRL_ADDR_HWREG_LOGOR_V_BASE;
GBaseAddr = XV_MIX_CTRL_ADDR_HWREG_LOGOG_V_BASE;
BBaseAddr = XV_MIX_CTRL_ADDR_HWREG_LOGOB_V_BASE;
for (y=0; y<Height; y++) {
for (x=0; x<Width; x+=4) {
Rword = (u32)RBuffer[y*Width+x] |
(((u32)RBuffer[y*Width+x+1])<<8) |
(((u32)RBuffer[y*Width+x+2])<<16) |
(((u32)RBuffer[y*Width+x+3])<<24);
Gword = (u32)GBuffer[y*Width+x] |
(((u32)GBuffer[y*Width+x+1])<<8) |
(((u32)GBuffer[y*Width+x+2])<<16) |
(((u32)GBuffer[y*Width+x+3])<<24);
Bword = (u32)BBuffer[y*Width+x] |
(((u32)BBuffer[y*Width+x+1])<<8) |
(((u32)BBuffer[y*Width+x+2])<<16) |
(((u32)BBuffer[y*Width+x+3])<<24);
XV_mix_WriteReg(MixPtr->Config.BaseAddress, (RBaseAddr+(y*Width+x)), Rword);
XV_mix_WriteReg(MixPtr->Config.BaseAddress, (GBaseAddr+(y*Width+x)), Gword);
XV_mix_WriteReg(MixPtr->Config.BaseAddress, (BBaseAddr+(y*Width+x)), Bword);
InstancePtr->Layer[XVMIX_LAYER_LOGO].RBuffer = RBuffer;
InstancePtr->Layer[XVMIX_LAYER_LOGO].GBuffer = GBuffer;
InstancePtr->Layer[XVMIX_LAYER_LOGO].BBuffer = BBuffer;
Status = XVMix_SetLayerWindow(InstancePtr, XVMIX_LAYER_LOGO, Win, 0);
return(Status);
can anybody help us with this? any information will be useful.
Re: Issue in enabling logo layer in video mixer ip.
Hi shantaramjagtap1994@,
The XAPP was released for the 2016.2 version of the IP. Since you are using a much newer version of the IP, I suggest building the example design listed in chapter 5 of PG243.
***Before you get to the step "Open IP Example Design", make sure that you have the logo layer enabled in the IP. This will then set a parameter in xparameters.h which enables our software application example to show how to configure the IP.
Xilinx Video Design Hub
