Issues With GStreamer Based Test Pattern and Encoding
Hello Everyone!
We are suffering a couple issues with UHD (3840x2160) within GStreamer.
Our environment is the ZCU-106 rev. C under Xilinx release 2018.2.
My specific issues/questions are:
  1. The "testvideosrc" smpte test pattern generator appears to be hugely CPU intensive.
  2. I am unable to create an AVC or HEVC [H.264 or H.265] encoded video which claims to be in the BT.709 colour-space.
  3. The GStreamer encoding quality of HEVC is awful compared to AVC.
Attached is a batch file which demonstrates the problem with HEVC.
The first problem is evidenced by the test requiring over ten minutes to run, as follows:
drwxr-xr-x  2 root root 4096 Nov 29 23:33 .
drwxr-xr-x 18 root root 4096 Nov 29 23:14 ..
-rwxr--r--  1 root root  874 Nov 29 23:20 xilinx-question.001.bash
root@zcu106_vcu_trd:/media/sata/xilinx-question.001.2018-11.29# time ./xilinx-question.001.bash >& xilinx-question.001.output
real    9m51.311s
user    10m35.698s
sys     0m38.826s
root@zcu106_vcu_trd:/media/sata/xilinx-question.001.2018-11.29# la
total 735976
-rw-r--r--  1 root root 753328610 Nov 29 23:43 xilinx-question.001.mp4
-rw-r--r--  1 root root    286964 Nov 29 23:43 xilinx-question.001.output
The second problem is evidenced by inspecting the stream properties in the ".mp4" file.
The third problem will be evident when you play the ".mp4" video file.
I've attached the test file and an image of the stream properties for reference (Xilinx won't allow me to attach the captured textual output).
Any help you can give is appreciated.
Thanks!
--Peimann
Kind Regards,
Peimann, S. M.
Toddlers are the Storm-Troopers of the Great God Entropy.
Physics: Not Just a Good Idea, It's THE LAW.
Re: Issues With GStreamer Based Test Pattern and Encoding
Hi @peimann,
As mentioned by @chrisar this was not implemented in 2018.3. Thus this is a feature request. You will need to wait at least 2019.1 to be released. But we cannot guaranty it will be implemented. It will be depending on the needs from all our customers.
You might want to contact your FAE for more details or to emphasize on your interest.
Best Regards,
@peimannI've replicated your results for both the CPU and the BT.709 color space results and I'm looking both of them on the ZCU106 Rev 1.0 board.
P.S. Sorry you couldn't add the text output.  If you can't attach the file, you could also try to add it in a code box at the end of your post.
Chris
Video Design Hub | Embedded SW Support
Thanks for Your Reply @chrisar,
The output is rather large.  Last time I tried to attach as a file the board rejected it.  I'll rename as a .text and try once again...
Did not like .text, will try as .txt...
That didn't work, either.  Will try as an archive with one file...
Kind Regards,
Peimann
Kind Regards,
Peimann, S. M.
@peimannThank you for the file.  I did some investigation and found that the large CPU usage is expected when using videotestsrc for such a large resolution.  The reason is that videotestsrc can't use a DMA copy, so the CPU has to do a memcopy which is loading down the CPU.
As for the second issue with color space that it going to take some time to find the root cause.  It isn't clear where the request to set BT.701 is being dropped.
Chris
Thanks for the first answer @chrisar, I appreciate your help.
Also, that you are still looking into the colour space issue.
I will try to determine whether HD is serviceable.  Do you know if DMA is adequate at that resolution?
Have you looked at the video generated using HEVC?  Mine shows frequent drop-out to gray, although that might be playback error.  I cannot tell.  The file is about 735 MByte, so uploading is a non-starter.
Kind Regards,
Peimann, S. M.
@peimannHD resolutions should be fine.  The VCU and support up to 1 stream at 4Kp60 or 4 Streams of 1080p60 since both are the same bandwidth.  But you do need to make sure that your full pipeline can support the bandwidth as the Programmable Logic (PL) can create custom video pipelines.
I did some testing with 100 frames rather than 3600, in order to speed up the testing and I didn't see any drop outs.  Keep in mind that 4Kp60 is pretty high bandwidth and needs to have a proper pipeline.  In  you case since the source is software generated there is a possibility that the generator does drop frames.  Also as you pointed out it could also depend on how you are viewing the results.
Let's keep this thread focused on the color space issue and if you have other questions open a new thread for new topics.
Chris
Thanks @chrisar,
I'll try to stay on topic in this thread.
That said, I will test and verify, so that throughput is a dead issue.
Have a Great Evening!
Kind Regards,
Peimann, S. M.
Good Morning @chrisar,
Have you had any luck finding any more information on the colour space problem?
Scott
Kind Regards,
Peimann, S. M.
@peimannWe are still looking into this.
Chris
We have confirmed that support for BT.709 has not been implemented in 2018.3 and earlier.
We have filed a CR (Change Request) and the plan is to address in a future release.
Chris
Good Afternoon @chrisar,
Thanks for the feed-back.
I've attached comparative outputs from the original test and under the vcu_sdirxtx build from the pre-built cases.
Can you give me a time estimate on when we might see an expected resolution date?
Thank You,
Scott M. Peimann
Kind Regards,
Peimann, S. M.
Hi @peimann,
Best Regards,
Thank You @florentw and @chrisar,
I'm going to close this issue based on the performance aspect.  I will write a new one to deal with only the colour-space issue that we are working to track down.
I really do appreciate the help you have given us.
Merry Christmas!
Kind Regards,
Peimann, S. M.
Thanks. Merry Christmas to you ;)
