Looking for board for SDI to MIPI CSI-2
Hello
I'm look for a SDI to CSI-2 that supports formats from SD up to 1080 30p and 60i
This product only has limited format support
 https://www.mouser.com/ProductDetail/Auvidea/70504?qs=sGAEpiMZZMu3sxpa5v1qrv9%252Bz890pMquCxL6tEG19Uw%3D
So wondering if you know of any other solution?
Many thanks
Tags (2)
Re: Looking for board for SDI to MIPI CSI-2
Hello scott@scottwalker.com.au
- SMPTE UHD-SDI Transmitter Subsystem IP supports your SDI usecase
  https://www.xilinx.com/support/documentation/ip_documentation/v_smpte_uhdsdi_tx_ss/v2_0/pg289-v-smpte-uhdsdi-tx-ss.pdf
- Xilinx also has MIPI CSI-2 TX Subsystem IP.
  You may want to check the following PG, to check if this IP can fit your usecase.
  https://www.xilinx.com/support/documentation/ip_documentation/mipi_csi2_tx_subsystem/v2_0/pg260-mipi-csi2-tx.pdf
Board such as ZCU106 (UltraScale+ MPSoC) has BNC connectors to in/out SDI. So, I think this board can do.
BTW, There is no connectors specific for MIPI CSI-2, but you can use FMC connectors to output your MIPI signals (2.5Gbps or less). Depends on your system requirement, you might need to build your own FMC daughther board.
https://www.xilinx.com/products/boards-and-kits/zcu106.html#hardware
One caveat is Xilinx do not have reference design (TRD) ready that matching your usecase.
You might need to build your design based on SDI Example design + CSI-2 Example Design.
Thanks & regards
Leo
Thanks & regards
Leo
Hi scott@scottwalker.com.au
Just to add on @karnanl reply, you can do this type of design on the ZCU102/ZCU104/ZCU106 with some FMC cards. But keep in mind that these boards are not production board only evaluation boards.
If you need a board that can work in production, I am not aware of any which can do this. You might want to contact a design services company to do a custom board for your needs.
I see that you are in Australia. I not fully aware of the design service companies there. Maybe @u4223374 has some ideas?Or you can contact a Xilinx sales/authorized distributor. They should be able to guide you.
Florent
Scholar u4223374
@florentw @karnanl We've previously used Blackbox Embedded (a Xilinx partner of some sort, based in Brisbane) for FPGA development work, and Extel (based in Melbourne) for PCB design and assembly. Both are expensive (normal when you want to outsource design) but do excellent work.
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Aoife
