Looking for reference project for MIPI CSI-2 receiver and Petalinux on ZCU102 or similar board
Hello Xilinx Community,
I am looking forward for reference project for MIPI CSI-2 receiver and Petalinux on ZCU102 or similar evaluation board which could be used as starting point for custom application. There is an example of pg232-mipi-csi2-rx.pdf with bare metal application, but do we have reference project for Petalinux?
Especially, I am interested to see HW design in PL, especially, type of DMA used and how this HW design will be translated to device tree and driver part.
Any support on reference project is appreciated.
Tags (2)
Re: Looking for reference project for MIPI CSI-2 receiver and Petalinux on ZCU102 or similar board
Hello
You may want to check the following URL.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/45940846/Zynq+UltraScale+MPSoC+Base+TRD+2018.3
Design module 6 should be a good start point.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/46727215/Zynq+UltraScale+MPSoC+Base+TRD+2018.3+-+Design+Module+6
You need to use Leopard LI-IMX274MIPI-FMC to run this reference design though.
Thanks & regards
Leo
Hello
Thanks & regards
Leo
Hello Leo,
Thanks a lot for this reference design. Studied it and I see that here used framebuffer for RAW10.
Our camera provides RAW12 and, as I see, framefuffer can not work with this format (only supports 8 and 10 bit), right? Do we have a reference design where video DMA block is used instead of video frame buffer for more flexible camera configurations?
Thank you.
Volodymyr.
Hello Volodymyr,
I did not aware of any reference design that fit your usecase. (PG232 Example use VDMA but it is not a Linux application )
Xilinx recommends using the Video Frame Buffer Read and Video Frame Buffer Write
for reading from or writing to memory when using Video IP such as the Video Processing Subsystem.
Your understanding is correct that this module only support 8/10-bits per color component.
Thanks & regards
Leo
Hello Leo,
finally we succeded to get first images with VDMA and Petalinux.
Thank you for your support.
Best regards,
Volodymyr.
