Observer galohtc
MIPI DPHY
I saw in the xapp1339 application note that I can implement a 2.5Gb DPHY logic using the GTH tranciever.
I need to know if i can implement the same logic using a GTY tranciever instead using the method described in the application note and if so, what are the required changes.
Re: MIPI DPHY
Hello @galohtc
XAPP1339 is a point solution for a specific customer. It is delivered "As Is". Support for this XAPP1339 is limited.
All the necessary files are provided with the XAPP and you need to match exact requirement of this XAPP1339 to utilize it for your design.
Bhushan
Re: MIPI DPHY
Hello @galohtc
Xilinx will release MIPI D-PHY IP that support 2.5 Gbps on Vivado 2019.1 release.
We are still testing the IP now, please wait until 2019.1.1 or 2019.1.2
Thanks & regards
Leo
Re: MIPI DPHY
Hi @galohtc ,
Is everything clear for you on this subject?
Thanks and Regards,
Observer galohtc
Re: MIPI DPHY
The only answer I was given is that I will get an answer with vivado 2019.1, so until the new version comes out I won't know if my question is answered ...
