Multi Stream Decoding and Encoding with VCU
I am trying to decode two encoded videos at the same time. I am using PG252 to understand how VCU works. In page 155,
But it's for same input.
What is the syntax for different input files?
Re: Multi Stream Decoding and Encoding with VCU
The case you are pointing to shows how to use the GStreamer tee plugin to replicate 1 stream multiple times and send it to the encoder.  That is what the note at the bottom of the code sample is trying to say.
Note: tee element is used to feed same input file into 4 decoder instances, user can use separate gst-launch-1.0 application to fed different inputs.
If you want to decode multiple different files, you just run multiple GStreamer launch pipelines.
gst-launch-1.0 filesrc location=input_0_1920x1080.mp4 ! qtdemux ! h265parse ! queue ! omxh265dec ! queue max-size-bytes=0 ! filesink location="output_0_1920x1080.yuv" &
gst-launch-1.0 filesrc location=input_1_1920x1080.mp4 ! qtdemux ! h265parse ! queue ! omxh265dec ! queue max-size-bytes=0 ! filesink location="output_1_1920x1080.yuv" &
gst-launch-1.0 filesrc location=input_2_1920x1080.mp4 ! qtdemux ! h265parse ! queue ! omxh265dec ! queue max-size-bytes=0 ! filesink location="output_2_1920x1080.yuv" &
gst-launch-1.0 filesrc location=input_3_1920x1080.mp4 ! qtdemux ! h265parse ! queue ! omxh265dec ! queue max-size-bytes=0 ! filesink location="output_3_1920x1080.yuv"
If you try to decode more streams that the hardware can handle you should see an allocation error.
Chris
Video Design Hub | Embedded SW Support
Thank you so much, it helped for 1080p videos, but failed when I try for 4kp30 or 4Kp15 videos.
Why doesnt it work?
Scholar watari
Hi @yildizbilgin
Did you set QoS parameter for VCU ?
$ devmem 0xFD370008 w 0x3
$ devmem 0xFD37001C w 0x3
$ devmem 0xFD380008 w 0x3
$ devmem 0xFD38001C w 0x3
$ devmem 0xFD390008 w 0x3
$ devmem 0xFD39001C w 0x3
$ devmem 0xFD3A0008 w 0x3
$ devmem 0xFD3A001C w 0x3
$ devmem 0xFD3B0008 w 0x3
$ devmem 0xFD3B001C w 0x3
$ devmem 0xFD380004 w 0xF
$ devmem 0xFD390004 w 0xF
$ devmem 0xFD3A0004 w 0xF
$ devmem 0xFD3B0004 w 0xF
$ devmem 0xFD380018 w 0xF
$ devmem 0xFD390018 w 0xF
$ devmem 0xFD3A0018 w 0xF
$ devmem 0xFD3B0018 w 0xF
Yeah, I've tried. Still doesnt work.
Scholar watari
Hi @yildizbilgin
Could you share your gstreamer pipeline ?
I'm an interesting this issue.
gst-launch-1.0 filesrc location="sunflower4Kp15_part1.mp4" ! qtdemux name=demux1 demux1.video_0 ! h264parse ! video/x-h264, alignment=au ! omxh264dec low-latency=0 ! omxh265enc ! video/x-h265, alignment=au ! filesink location="output_1.h265" & gst-launch-1.0 filesrc location="sunflower4Kp15_part2.mp4" ! qtdemux name=demux2 demux2.video_0 ! h264parse ! video/x-h264, alignment=au ! omxh264dec low-latency=0 ! omxh265enc ! video/x-h265, alignment=au ! filesink location="output_2.h265"
I inspire from :
Scholar watari
Hi @yildizbilgin
I'd like to duplicate your environment, if possibel.
Would you share the following result, if possible ?
$ mediainfo <your mp4 file>
note)
"mediainfo" is a utility of media file on Linux. (Ubuntu/Debian)
I am using windows so I have these:
Hi @yildizbilgin
Your log clearly mention that you do not have enough memory. What if you try with less or smaller streams?
Probably you need to move to a board with more DDR as the ZCU106.
Scholar watari
Hi @yildizbilgin
As @florentw  already mentioned at other post, the route cause is memory allocation error.
In this case (VCU TRD), there is not specific cma (Continuous Memory Allocator) setting at Linux kernel argument and default value is 16MB.
VCU software, like gstreamer and so on, requires memory to share it between hardware resource and userland software.
This case (resolution is 3840x2160) is required large memory by it.
At least it needs about 32MB.
So, software give up "memory allocation".
Here is solution for like this issue.
# Solution
- Change cma value from default (16MB) to 128MB (maxmum value)
1. Execute petalinux-config
2. Exnter DTG Settings ---> Kernel Bootargs --->
3. Edit it
4. Add "cma=128M" on it
5. Execute petalinux-build
Hello I normally follow this instruction:
Under "DTG Settings" ->
"Kernel Bootargs" ->
Un-select "generate boot args automatically" ->
Enter "user set kernel bootargs" -> Paste in the following line
earlycon clk_ignore_unused earlyprintk root=/dev/mmcblk0p2 rw rootwait cma=1024M
So, should I just write cma=128M instead of the above line?
HI @yildizbilgin
I think that if you have CMA=1024M this is enough you should keep this value
Hi @florentw ,
Maybe I should enable the PL DDR?
How should I connect the PL DDR in ZCU104 BSP project? Do you have an idea?
Thanks...
HI @yildizbilgin
Yes, it might worth to try. This is documented in PG252 page 113.
Yes, I have seen this but it didnt work. I think I should also add ddr4 IP block to the vivado project which isnt explained in PG252. I dont know how to do it.
Hi @yildizbilgin
You need to add the Zynq UltraScale+ EV Architecture Video Codec Unit DDR4 LogiCORE IP as described in pg252 chapter 6 ...
Hello @watari ,
I have already configure Kernel bootargs as
Is it wrong?
HI @yildizbilgin
No it should be fine
So what should I change? My problem still exists. I cant decode or encode two 4Kp30 videos at the same time.
