No Video caused by flip_done timed out on VCU TRD 2019.1
Hello xilinx support
I use the precompiled VCU TRD 2019.1 - VCU Audio
The image used is
../rdf0428-zcu106-vcu-trd-2018-3/images/vcu_audio
When I run the modetest command on a monitor 4k native to force the monitor to use full HD(1920x1080) resolution the Video goes down an a black screen is displayed an error occurs on the dmesg (see full dmesg at the end of the post)
[ 5624.114628] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[ 5667.564025] [drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [CRTC:38:crtc-0] flip_done timed out
[ 5677.803999] [drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [PLANE:30:plane-0] flip_done timed out
[ 5688.044012] [drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [PLANE:36:plane-6] flip_done timed out
[ 5709.803984] [drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [CRTC:38:crtc-0] flip_done timed out
[ 5720.043971] [drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [PLANE:30:plane-0] flip_done timed out
[ 5730.283977] [drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [PLANE:36:plane-6] flip_done timed out
Step to reproduce:
root@zcu106_vcu_trd:~# modetest -D a0070000.v_mix -s 40:1920x1080-60@AR24
setting mode 1920x1080-60Hz@AR24 on connectors 40, crtc 38
during this time in another terminal I play the video using this command whith an encoder set to 1080p60 resolution
root@zcu106_vcu_trd:~# gst-launch-1.0 --no-fault rtspsrc location=rtsp://192.168.0.196:554/stream latency=10 name=demux demux. ! rtph264depay ! h264parse ! queue max-size-buffers=0 max-size-bytes=0 ! omxh264dec internal-entropy-buffers=15 low-latency=false ! queue max-size-buffers=0 max-size-bytes=0 ! kmssink bus-id=a0070000.v_mix max-lateness=20000000 plane-id=30 qos=true sync=false demux. ! rtpmp4adepay ! faad ! audioconvert ! audioresample ! audio/x-raw, rate=48000, channnels=2, format=S24_32LE ! alsasink device=hw:2,0
stop the video
stop modetest
re run
during this time in another terminal I play the video using this command with another encoder which has a different stream resolution(4k)
root@zcu106_vcu_trd:~# gst-launch-1.0 --no-fault rtspsrc location=rtsp://192.168.0.19:554/stream latency=10 name=demux demux. ! rtph264depay ! h264parse ! queue max-size-buffers=0 max-size-bytes=0 ! omxh264dec internal-entropy-buffers=15 low-latency=false ! queue max-size-buffers=0 max-size-bytes=0 ! kmssink bus-id=a0070000.v_mix max-lateness=20000000 plane-id=30 qos=true sync=false demux. ! rtpmp4adepay ! faad ! audioconvert ! audioresample ! audio/x-raw, rate=48000, channnels=2, format=S24_32LE ! alsasink device=hw:2,0
At this point the video is stopping and the monitor detect no signal at HDMI
root@zcu106_vcu_trd:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.0-xilinx-v2019.1 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Sat May 25 20:08:48 UTC 2019
[ 0.000000] Machine model: ZynqMP ZCU106 RevA
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] bootconsole [cdns0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 1700 MiB at 0x000000000a800000
[ 0.000000] On node 0 totalpages: 1048320
[ 0.000000] DMA32 zone: 7165 pages used for memmap
[ 0.000000] DMA32 zone: 0 pages reserved
[ 0.000000] DMA32 zone: 524032 pages, LIFO batch:63
[ 0.000000] Normal zone: 7168 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:63
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0
[ 0.000000] percpu: Embedded 23 pages/cpu @(____ptrval____) s53656 r8192 d32360 u94208
[ 0.000000] pcpu-alloc: s53656 r8192 d32360 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1033987
[ 0.000000] Kernel command line: earlycon clk_ignore_unused consoleblank=0 cma=1700M uio_pdrv_genirq.of_id=generic-uio
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB: mapped [mem 0x06800000-0x0a800000] (64MB)
[ 0.000000] Memory: 2158508K/4193280K available (10812K kernel code, 638K rwdata, 5444K rodata, 832K init, 509K bss, 293972K reserved, 1740800K cma-reserved)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] irq-xilinx: /amba_pl@0/interrupt-controller@a0055000: num_irq=3, edge=0x0
[ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns
[ 0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[ 0.008315] Console: colour dummy device 80x25
[ 0.012377] console [tty0] enabled
[ 0.015744] bootconsole [cdns0] disabled
[ 0.019656] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
[ 0.019669] pid_max: default: 32768 minimum: 301
[ 0.019783] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.019801] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.020496] ASID allocator initialised with 32768 entries
[ 0.020550] rcu: Hierarchical SRCU implementation.
[ 0.020932] EFI services will not be available.
[ 0.021052] smp: Bringing up secondary CPUs ...
[ 0.021327] Detected VIPT I-cache on CPU1
[ 0.021355] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.021660] Detected VIPT I-cache on CPU2
[ 0.021679] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.021964] Detected VIPT I-cache on CPU3
[ 0.021983] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.022027] smp: Brought up 1 node, 4 CPUs
[ 0.022060] SMP: Total of 4 processors activated.
[ 0.022069] CPU features: detected: 32-bit EL0 Support
[ 0.023589] CPU: All CPU(s) started at EL2
[ 0.023605] alternatives: patching kernel code
[ 0.024471] devtmpfs: initialized
[ 0.030874] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.030897] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.066251] xor: measuring software checksum speed
[ 0.103985] 8regs : 2375.000 MB/sec
[ 0.144013] 8regs_prefetch: 2052.000 MB/sec
[ 0.184042] 32regs : 2724.000 MB/sec
[ 0.224071] 32regs_prefetch: 2308.000 MB/sec
[ 0.224079] xor: using function: 32regs (2724.000 MB/sec)
[ 0.224093] pinctrl core: initialized pinctrl subsystem
[ 0.224700] NET: Registered protocol family 16
[ 0.224985] audit: initializing netlink subsys (disabled)
[ 0.225053] audit: type=2000 audit(0.216:1): state=initialized audit_enabled=0 res=1
[ 0.225443] cpuidle: using governor menu
[ 0.225582] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.225595] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.226294] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.242230] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.308206] raid6: int64x1 gen() 445 MB/s
[ 0.376268] raid6: int64x1 xor() 453 MB/s
[ 0.444346] raid6: int64x2 gen() 680 MB/s
[ 0.512341] raid6: int64x2 xor() 599 MB/s
[ 0.580391] raid6: int64x4 gen() 981 MB/s
[ 0.648439] raid6: int64x4 xor() 733 MB/s
[ 0.716483] raid6: int64x8 gen() 1162 MB/s
[ 0.784495] raid6: int64x8 xor() 759 MB/s
[ 0.852573] raid6: neonx1 gen() 735 MB/s
[ 0.920608] raid6: neonx1 xor() 879 MB/s
[ 0.988662] raid6: neonx2 gen() 1127 MB/s
[ 1.056690] raid6: neonx2 xor() 1172 MB/s
[ 1.124740] raid6: neonx4 gen() 1476 MB/s
[ 1.192787] raid6: neonx4 xor() 1417 MB/s
[ 1.260826] raid6: neonx8 gen() 1531 MB/s
[ 1.328879] raid6: neonx8 xor() 1459 MB/s
[ 1.328887] raid6: using algorithm neonx8 gen() 1531 MB/s
[ 1.328894] raid6: .... xor() 1459 MB/s, rmw enabled
[ 1.328902] raid6: using neon recovery algorithm
[ 1.329128] xilinx-gpio a0053000.gpio: Input clock not found
[ 1.329836] SCSI subsystem initialized
[ 1.329882] libata version 3.00 loaded.
[ 1.330029] usbcore: registered new interface driver usbfs
[ 1.330067] usbcore: registered new interface driver hub
[ 1.330106] usbcore: registered new device driver usb
[ 1.330178] media: Linux media interface: v0.10
[ 1.330207] videodev: Linux video capture interface: v2.00
[ 1.330237] pps_core: LinuxPPS API ver. 1 registered
[ 1.330246] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.330267] PTP clock support registered
[ 1.330295] EDAC MC: Ver: 3.0.0
[ 1.330708] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
[ 1.330964] FPGA manager framework
[ 1.331152] Advanced Linux Sound Architecture Driver Initialized.
[ 1.331441] Bluetooth: Core ver 2.22
[ 1.331470] NET: Registered protocol family 31
[ 1.331478] Bluetooth: HCI device and connection manager initialized
[ 1.331491] Bluetooth: HCI socket layer initialized
[ 1.331500] Bluetooth: L2CAP socket layer initialized
[ 1.331526] Bluetooth: SCO socket layer initialized
[ 1.331857] clocksource: Switched to clocksource arch_sys_counter
[ 1.331934] VFS: Disk quotas dquot_6.6.0
[ 1.331977] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.336365] NET: Registered protocol family 2
[ 1.336731] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[ 1.336783] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 1.336991] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.337372] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.337440] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.337518] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.337675] NET: Registered protocol family 1
[ 1.337884] RPC: Registered named UNIX socket transport module.
[ 1.337894] RPC: Registered udp transport module.
[ 1.337901] RPC: Registered tcp transport module.
[ 1.337908] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.338154] PCI: CLS 0 bytes, default 64
[ 1.338249] Trying to unpack rootfs image as initramfs...
[ 7.629302] Freeing initrd memory: 145072K
[ 7.629704] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 7.629870] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 7.630903] Initialise system trusted keyrings
[ 7.630991] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 7.631689] NFS: Registering the id_resolver key type
[ 7.631707] Key type id_resolver registered
[ 7.631714] Key type id_legacy registered
[ 7.631727] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 7.631746] jffs2: version 2.2. (NAND) \xc2\xa9 2001-2006 Red Hat, Inc.
[ 8.719701] NET: Registered protocol family 38
[ 8.778664] Key type asymmetric registered
[ 8.778674] Asymmetric key parser 'x509' registered
[ 8.778721] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 8.778733] io scheduler noop registered
[ 8.778741] io scheduler deadline registered
[ 8.778784] io scheduler cfq registered (default)
[ 8.778793] io scheduler mq-deadline registered
[ 8.778801] io scheduler kyber registered
[ 8.780761] xilinx-frmbuf a0010000.v_frmbuf_wr: failed to get ap_clk (-517)
[ 8.780807] xilinx-frmbuf a0040000.v_frmbuf_rd: failed to get ap_clk (-517)
[ 8.780856] xilinx-frmbuf a0260000.v_frmbuf_wr: failed to get ap_clk (-517)
[ 8.807011] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 8.811701] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 8.816274] brd: module loaded
[ 8.820095] loop: module loaded
[ 8.821211] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 8.822658] libphy: Fixed MDIO Bus: probed
[ 8.823957] tun: Universal TUN/TAP device driver, 1.6
[ 8.824098] CAN device driver interface
[ 8.825457] usbcore: registered new interface driver asix
[ 8.825492] usbcore: registered new interface driver ax88179_178a
[ 8.825525] usbcore: registered new interface driver cdc_ether
[ 8.825556] usbcore: registered new interface driver net1080
[ 8.825588] usbcore: registered new interface driver cdc_subset
[ 8.825619] usbcore: registered new interface driver zaurus
[ 8.825659] usbcore: registered new interface driver cdc_ncm
[ 8.826311] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 8.826321] ehci-pci: EHCI PCI platform driver
[ 8.826712] usbcore: registered new interface driver uas
[ 8.826752] usbcore: registered new interface driver usb-storage
[ 8.827381] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[ 8.827465] i2c /dev entries driver
[ 8.828058] si5324 0-0068: si5319 probed
[ 8.901735] si5324 0-0068: si5319 probe successful
[ 8.902809] xilinx-video amba_pl@0:vcap_hdmi: /amba_pl@0/vcap_hdmi/ports/port@0 initialization failed
[ 8.902825] xilinx-video amba_pl@0:vcap_hdmi: DMA initialization failed
[ 8.902870] xilinx-video amba_pl@0:vcap_csi: /amba_pl@0/vcap_csi/ports/port@0 initialization failed
[ 8.902883] xilinx-video amba_pl@0:vcap_csi: DMA initialization failed
[ 8.903310] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: assuming all required clocks are enabled!
[ 8.903419] xilinx-csi2rxss a00f0000.mipi_csi2_rx_subsystem: Xilinx CSI2 Rx Subsystem device found!
[ 8.904893] xilinx-vpss-scaler a0080000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[ 8.904908] xilinx-vpss-scaler a0080000.v_proc_ss: assuming all required clocks are enabled!
[ 8.904979] xilinx-vpss-scaler a0200000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[ 8.904993] xilinx-vpss-scaler a0200000.v_proc_ss: assuming all required clocks are enabled!
[ 8.905265] usbcore: registered new interface driver uvcvideo
[ 8.905274] USB Video Class driver (1.1.1)
[ 8.905946] Bluetooth: HCI UART driver ver 2.3
[ 8.905957] Bluetooth: HCI UART protocol H4 registered
[ 8.905965] Bluetooth: HCI UART protocol BCSP registered
[ 8.905993] Bluetooth: HCI UART protocol LL registered
[ 8.906002] Bluetooth: HCI UART protocol ATH3K registered
[ 8.906026] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 8.906081] Bluetooth: HCI UART protocol Intel registered
[ 8.906106] Bluetooth: HCI UART protocol QCA registered
[ 8.906146] usbcore: registered new interface driver bcm203x
[ 8.906181] usbcore: registered new interface driver bpa10x
[ 8.906219] usbcore: registered new interface driver bfusb
[ 8.906256] usbcore: registered new interface driver btusb
[ 8.906265] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 8.906316] usbcore: registered new interface driver ath3k
[ 8.906453] EDAC MC: ECC not enabled
[ 8.906668] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 8.907423] sdhci: Secure Digital Host Controller Interface driver
[ 8.907432] sdhci: Copyright(c) Pierre Ossman
[ 8.907439] sdhci-pltfm: SDHCI platform and OF driver helper
[ 8.907837] ledtrig-cpu: registered to indicate activity on CPUs
[ 8.907908] zynqmp_firmware_probe Platform Management API v1.1
[ 8.907918] zynqmp_firmware_probe Trustzone version v1.0
[ 8.910689] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[ 8.934421] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
[ 8.934931] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[ 8.934952] zynqmp_aes zynqmp_aes: AES Successfully Registered
[ 8.935159] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[ 8.935352] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[ 8.935579] usbcore: registered new interface driver usbhid
[ 8.935588] usbhid: USB HID core driver
[ 8.939603] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 8.940088] usbcore: registered new interface driver snd-usb-audio
[ 8.940775] xlnx_formatter_pcm a0052000.audio_formatter: failed to get m_axis_mm2s_aclk(-517)
[ 8.941879] xlnx_formatter_pcm a0051000.audio_formatter: sound card device will use DAI link: i2s_transmitter
[ 8.941923] xlnx_formatter_pcm a0051000.audio_formatter: sound card device will use DAI link: i2s_receiver
[ 8.942027] xlnx_formatter_pcm a0051000.audio_formatter: pcm platform device registered
[ 8.942338] xlnx_i2s a00c0000.i2s_receiver: xlnx_i2s_capture DAI registered
[ 8.942444] xlnx_i2s a00d0000.i2s_transmitter: xlnx_i2s_playback DAI registered
[ 8.943111] xlnx_snd_card xlnx_snd_card.0.auto: snd-soc-dummy-dai <-> a00d0000.i2s_transmitter mapping ok
[ 8.943414] xlnx_snd_card xlnx_snd_card.0.auto: snd-soc-dummy-dai <-> a00c0000.i2s_receiver mapping ok
[ 8.943754] xlnx_snd_card xlnx_snd_card.0.auto: xlnx-i2s-snd-card-0 registered
[ 8.943828] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 8.944241] Initializing XFRM netlink socket
[ 8.944321] NET: Registered protocol family 10
[ 8.944702] Segment Routing with IPv6
[ 8.944792] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 8.945120] NET: Registered protocol family 17
[ 8.945136] NET: Registered protocol family 15
[ 8.945154] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 8.945201] can: controller area network core (rev 20170425 abi 9)
[ 8.945232] NET: Registered protocol family 29
[ 8.945242] can: raw protocol (rev 20170425)
[ 8.945250] can: broadcast manager protocol (rev 20170425 t)
[ 8.945260] can: netlink gateway (rev 20170425) max_hops=1
[ 8.945421] Bluetooth: RFCOMM TTY layer initialized
[ 8.945433] Bluetooth: RFCOMM socket layer initialized
[ 8.945448] Bluetooth: RFCOMM ver 1.11
[ 8.945460] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.945467] Bluetooth: BNEP filters: protocol multicast
[ 8.945477] Bluetooth: BNEP socket layer initialized
[ 8.945485] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 8.945495] Bluetooth: HIDP socket layer initialized
[ 8.945642] 9pnet: Installing 9P2000 support
[ 8.945663] Key type dns_resolver registered
[ 8.946051] registered taskstats version 1
[ 8.946060] Loading compiled-in X.509 certificates
[ 8.946382] Btrfs loaded, crc32c=crc32c-generic
[ 8.953363] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 43, base_baud = 6249375) is a xuartps
[ 10.421692] console [ttyPS0] enabled
[ 10.425729] GPIO IRQ not connected
[ 10.429131] XGpio: gpio@a0053000: registered, base is 480
[ 10.435429] of-fpga-region fpga-full: FPGA Region probed
[ 10.441566] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[ 10.448157] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 10.455265] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 10.462377] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 10.469487] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 10.476596] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 10.483706] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 10.490811] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 10.497925] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 10.505110] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[ 10.512223] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[ 10.519338] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[ 10.526451] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[ 10.533564] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[ 10.540676] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[ 10.547789] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[ 10.554900] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[ 10.562000] xilinx-frmbuf a0010000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[ 10.569460] xilinx-frmbuf a0010000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
[ 10.578117] xilinx-frmbuf a0040000.v_frmbuf_rd: Xilinx AXI frmbuf DMA_MEM_TO_DEV
[ 10.585575] xilinx-frmbuf a0040000.v_frmbuf_rd: Xilinx AXI FrameBuffer Engine Driver Probed!!
[ 10.594228] xilinx-frmbuf a0260000.v_frmbuf_wr: Xilinx AXI frmbuf DMA_DEV_TO_MEM
[ 10.601687] xilinx-frmbuf a0260000.v_frmbuf_wr: Xilinx AXI FrameBuffer Engine Driver Probed!!
[ 10.610396] xlnx-mixer a0070000.v_mix: vtc bridge property not present
[ 10.617048] xlnx-mixer a0070000.v_mix: Xilinx Mixer driver probed success
[ 10.624182] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[ 10.634541] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[ 10.645237] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[ 10.653290] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[ 10.661695] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 10.674176] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 10.686869] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[ 10.697053] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[ 10.704073] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 10.710682] [drm] No driver support for vblank timestamp query.
[ 10.716663] xlnx-drm xlnx-drm.1: bound fd4a0000.zynqmp-display (ops 0xffffff8008bcf900)
[ 10.891042] Console: switching to colour frame buffer device 240x67
[ 10.914010] zynqmp-display fd4a0000.zynqmp-display: fb0: frame buffer device
[ 10.921421] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[ 10.929605] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[ 10.938719] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[ 10.946678] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 10.955722] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 10.966444] scsi host0: ahci-ceva
[ 10.970060] scsi host1: ahci-ceva
[ 10.973551] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 41
[ 10.981536] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 41
[ 10.990242] m25p80 spi0.0: found n25q512a, expected m25p80
[ 10.996283] m25p80 spi0.0: n25q512a (131072 Kbytes)
[ 11.001226] 4 fixed-partitions partitions found on MTD device spi0.0
[ 11.007631] Creating 4 MTD partitions on "spi0.0":
[ 11.012463] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[ 11.018726] 0x000000100000-0x000000600000 : "qspi-linux"
[ 11.024480] 0x000000600000-0x000000620000 : "qspi-device-tree"
[ 11.030749] 0x000000620000-0x000000c00000 : "qspi-rootfs"
[ 11.038674] macb ff0e0000.ethernet: Not enabling partial store and forward
[ 11.046113] libphy: MACB_mii_bus: probed
[ 11.055079] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[ 11.068254] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 31 (00:0a:35:00:22:03)
[ 11.078558] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 11.085185] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[ 11.091738] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[ 11.098290] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[ 11.106182] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[ 11.112164] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[ 11.120350] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 11.125897] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 11.134528] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810
[ 11.144023] xhci-hcd xhci-hcd.1.auto: irq 66, io mem 0xfe200000
[ 11.150206] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 11.158545] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.165832] usb usb1: Product: xHCI Host Controller
[ 11.170752] usb usb1: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd
[ 11.177511] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 11.182712] hub 1-0:1.0: USB hub found
[ 11.186521] hub 1-0:1.0: 1 port detected
[ 11.190663] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 11.196206] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 11.203943] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 11.214174] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 11.225937] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.236626] usb usb2: Product: xHCI Host Controller
[ 11.244941] usb usb2: Manufacturer: Linux 4.19.0-xilinx-v2019.1 xhci-hcd
[ 11.255109] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 11.263677] hub 2-0:1.0: USB hub found
[ 11.270857] hub 2-0:1.0: 1 port detected
[ 11.279350] pca953x 1-0020: 1-0020 supply vcc not found, using dummy regulator
[ 11.290018] pca953x 1-0020: Linked as a consumer to regulator.0
[ 11.300073] pca953x 1-0021: 1-0021 supply vcc not found, using dummy regulator
[ 11.302059] ata1: SATA link down (SStatus 0 SControl 330)
[ 11.310695] pca953x 1-0021: Linked as a consumer to regulator.0
[ 11.319418] ata2: SATA link down (SStatus 0 SControl 330)
[ 11.329756] random: fast init done
[ 11.344230] ina2xx 5-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.354299] ina2xx 5-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.364311] ina2xx 5-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.374275] ina2xx 5-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.384191] ina2xx 5-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.394045] ina2xx 5-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.403936] ina2xx 5-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.413768] ina2xx 5-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.423545] ina2xx 5-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.433226] ina2xx 5-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.442449] i2c i2c-1: Added multiplexed i2c bus 5
[ 11.450691] ina2xx 6-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[ 11.460300] ina2xx 6-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.469864] ina2xx 6-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.479357] ina2xx 6-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.488793] ina2xx 6-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.498177] ina2xx 6-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.507499] ina2xx 6-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.516819] ina2xx 6-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 11.525675] i2c i2c-1: Added multiplexed i2c bus 6
[ 11.566421] i2c i2c-1: Added multiplexed i2c bus 7
[ 11.573809] i2c i2c-1: Added multiplexed i2c bus 8
[ 11.581037] pca954x 1-0075: registered 4 multiplexed busses for I2C mux pca9544
[ 11.590828] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 33
[ 11.600994] at24 9-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[ 11.610201] i2c i2c-2: Added multiplexed i2c bus 9
[ 11.617704] i2c i2c-2: Added multiplexed i2c bus 10
[ 11.627198] si570 11-005d: registered, current frequency 300000000 Hz
[ 11.636188] i2c i2c-2: Added multiplexed i2c bus 11
[ 11.643688] i2c i2c-2: Added multiplexed i2c bus 12
[ 11.651228] si5324 13-0069: si5328 probed
[ 11.717651] si5324 13-0069: si5328 probe successful
[ 11.724869] i2c i2c-2: Added multiplexed i2c bus 13
[ 11.732252] i2c i2c-2: Added multiplexed i2c bus 14
[ 11.739511] i2c i2c-2: Added multiplexed i2c bus 15
[ 11.746779] i2c i2c-2: Added multiplexed i2c bus 16
[ 11.753918] pca954x 2-0074: registered 8 multiplexed busses for I2C switch pca9548
[ 11.764128] i2c i2c-2: Added multiplexed i2c bus 17
[ 11.771406] i2c i2c-2: Added multiplexed i2c bus 18
[ 11.778628] i2c i2c-2: Added multiplexed i2c bus 19
[ 11.786205] i2c i2c-2: Added multiplexed i2c bus 20
[ 11.793358] i2c i2c-2: Added multiplexed i2c bus 21
[ 11.800471] i2c i2c-2: Added multiplexed i2c bus 22
[ 11.807519] i2c i2c-2: Added multiplexed i2c bus 23
[ 11.814535] i2c i2c-2: Added multiplexed i2c bus 24
[ 11.821377] pca954x 2-0075: registered 8 multiplexed busses for I2C switch pca9548
[ 11.830966] i2c i2c-2: of_i2c: modalias failure on /amba/i2c@ff030000/i2cswitch@75
[ 11.840551] i2c i2c-2: Failed to create I2C device for /amba/i2c@ff030000/i2cswitch@75
[ 11.850511] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 34
[ 11.863131] IMX274 3-001a: imx274_set_test_pattern error = -5
[ 11.870938] IMX274 3-001a: Error -5 setup default controls
[ 11.878519] IMX274: probe of 3-001a failed with error -5
[ 11.886196] xilinx-video amba_pl@0:vcap_hdmi: device registered
[ 11.894426] xilinx-video amba_pl@0:vcap_csi: Entity type for entity a00f0000.mipi_csi2_rx_subsystem was not initialized!
[ 11.907387] xilinx-video amba_pl@0:vcap_csi: device registered
[ 11.915487] xilinx-video amba_pl@0:vcap_csi: Entity type for entity a0250000.v_demosaic was not initialized!
[ 11.927414] xilinx-demosaic a0250000.v_demosaic: Xilinx Video Demosaic Probe Successful
[ 11.937927] xilinx-video amba_pl@0:vcap_csi: Entity type for entity a0270000.v_gamma_lut was not initialized!
[ 11.950011] xilinx-gamma-lut a0270000.v_gamma_lut: Xilinx 8-bit Video Gamma Correction LUT registered
[ 11.961661] xilinx-video amba_pl@0:vcap_csi: Entity type for entity a0240000.v_proc_ss was not initialized!
[ 11.973646] xilinx-vpss-csc a0240000.v_proc_ss: VPSS CSC 8-bit Color Depth Probe Successful
[ 11.984420] xilinx-vpss-scaler a0080000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[ 11.996896] xilinx-vpss-scaler a0080000.v_proc_ss: assuming all required clocks are enabled!
[ 12.007646] xilinx-video amba_pl@0:vcap_hdmi: Entity type for entity a0080000.v_proc_ss was not initialized!
[ 12.019798] xilinx-vpss-scaler a0080000.v_proc_ss: Num Hori Taps 8
[ 12.028285] xilinx-vpss-scaler a0080000.v_proc_ss: Num Vert Taps 8
[ 12.036746] xilinx-vpss-scaler a0080000.v_proc_ss: VPSS Scaler Probe Successful
[ 12.046487] xilinx-vpss-scaler a0200000.v_proc_ss: xlnx,v-vpss-scaler - compatible string is getting deprecated!
[ 12.059011] xilinx-vpss-scaler a0200000.v_proc_ss: assuming all required clocks are enabled!
[ 12.069862] xilinx-video amba_pl@0:vcap_csi: Entity type for entity a0200000.v_proc_ss was not initialized!
[ 12.082053] xilinx-vpss-scaler a0200000.v_proc_ss: Num Hori Taps 8
[ 12.090712] xilinx-vpss-scaler a0200000.v_proc_ss: Num Vert Taps 8
[ 12.099380] xilinx-vpss-scaler a0200000.v_proc_ss: VPSS Scaler Probe Successful
[ 12.109512] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 60s
[ 12.121319] cdns-wdt ff150000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 10s
[ 12.133160] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1199880 KHz
[ 12.143242] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[ 12.183864] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[ 12.200422] xlnx_formatter_pcm a0052000.audio_formatter: sound card device will use DAI link: v_hdmi_tx_ss
[ 12.212859] xlnx_formatter_pcm a0052000.audio_formatter: sound card device will use DAI link: v_hdmi_rx_ss
[ 12.225411] xlnx_snd_card xlnx_snd_card.2.auto: ASoC: CODEC DAI i2s-hifi not registered
[ 12.236203] xlnx_snd_card xlnx_snd_card.2.auto: xlnx-hdmi-snd-card-1 registration failed
[ 12.247115] xlnx_formatter_pcm a0052000.audio_formatter: pcm platform device registered
[ 12.258085] xlnx_snd_card xlnx_snd_card.2.auto: ASoC: CODEC DAI i2s-hifi not registered
[ 12.268994] xlnx_snd_card xlnx_snd_card.2.auto: xlnx-hdmi-snd-card-1 registration failed
[ 12.280135] xlnx_snd_card xlnx_snd_card.2.auto: ASoC: CODEC DAI i2s-hifi not registered
[ 12.291071] xlnx_snd_card xlnx_snd_card.2.auto: xlnx-hdmi-snd-card-1 registration failed
[ 12.304508] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 12.314605] rtc_zynqmp ffa60000.rtc: setting system clock to 2019-07-10 11:00:17 UTC (1562756417)
[ 12.326515] of_cfs_init
[ 12.331960] of_cfs_init: OK
[ 12.337857] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 12.348813] xlnx_snd_card xlnx_snd_card.2.auto: ASoC: CODEC DAI i2s-hifi not registered
[ 12.359903] xlnx_snd_card xlnx_snd_card.2.auto: xlnx-hdmi-snd-card-1 registration failed
[ 12.417711] mmc0: new high speed SDHC card at address aaaa
[ 12.426765] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[ 12.435909] mmcblk0: p1
[ 12.442127] xlnx_snd_card xlnx_snd_card.2.auto: ASoC: CODEC DAI i2s-hifi not registered
[ 12.453268] xlnx_snd_card xlnx_snd_card.2.auto: xlnx-hdmi-snd-card-1 registration failed
[ 12.494141] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 12.503862] clk: Not disabling unused clocks
[ 12.511328] ALSA device list:
[ 12.517499] #0: xlnx-i2s-snd-card-0
[ 12.524339] #1: DisplayPort monitor
[ 12.531428] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 12.540347] Freeing unused kernel memory: 832K
[ 12.543293] cfg80211: failed to load regulatory.db
[ 12.575881] Run /init as init process
[ 12.739639] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 12.787077] udevd[2044]: starting version 3.2.5
[ 12.795445] random: udevd: uninitialized urandom read (16 bytes read)
[ 12.805458] random: udevd: uninitialized urandom read (16 bytes read)
[ 12.815458] random: udevd: uninitialized urandom read (16 bytes read)
[ 12.830272] udevd[2045]: starting eudev-3.2.5
[ 12.886633] xlnx_snd_card xlnx_snd_card.2.auto: ASoC: CODEC DAI i2s-hifi not registered
[ 12.898147] xlnx_snd_card xlnx_snd_card.2.auto: xlnx-hdmi-snd-card-1 registration failed
[ 12.938547] mali: loading out-of-tree module taints kernel.
[ 12.963765] xlnx_snd_card xlnx_snd_card.2.auto: ASoC: CODEC DAI i2s-hifi not registered
[ 12.975351] xlnx_snd_card xlnx_snd_card.2.auto: xlnx-hdmi-snd-card-1 registration failed
[ 12.988482] xilinx-vphy a0060000.vid_phy_controller: probed
[ 12.989858] dp159 0-005e: probed
[ 12.997952] VPhy version : 02.02 (0000)
[ 13.008864] dp159 0-005e: probe successful
[ 13.013152] xilinx-vphy a0060000.vid_phy_controller: probe successful
[ 13.020012] xlnx_snd_card xlnx_snd_card.2.auto: ASoC: CODEC DAI i2s-hifi not registered
[ 13.040421] xlnx_snd_card xlnx_snd_card.2.auto: xlnx-hdmi-snd-card-1 registration failed
[ 13.040815] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: probed
[ 13.041569] xilinx-hdmi-rx a0000000.v_hdmi_rx_ss: probed
[ 13.044046] xvphy_phy_init((____ptrval____)).
[ 13.044057] xvphy_phy_init((____ptrval____)).
[ 13.044068] xvphy_phy_init((____ptrval____)).
[ 13.052816] xilinx-hdmi-rx a0000000.v_hdmi_rx_ss: Using 2 EDID blocks (256 bytes) from 'xilinx/xilinx-hdmi-rx-edid.bin'.
[ 13.069046] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: hdmi tx audio initialized
[ 13.069051] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: probe successful
[ 13.069379] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 13.076811]
Successfully loaded edid.
[ 13.084289] [drm] No driver support for vblank timestamp query.
[ 13.084499] xlnx-drm xlnx-drm.0: bound a0070000.v_mix (ops 0xffffff8008bcbae8)
[ 13.084815] xlnx_snd_card xlnx_snd_card.2.auto: ASoC: CODEC DAI xlnx_hdmi_rx not registered
[ 13.084821] xlnx_snd_card xlnx_snd_card.2.auto: xlnx-hdmi-snd-card-1 registration failed
[ 13.091820] xilinx-video amba_pl@0:vcap_hdmi: Entity type for entity a0000000.v_hdmi_rx_ss was not initialized!
[ 13.106024] xlnx-drm xlnx-drm.0: bound a0020000.v_hdmi_tx_ss (ops xlnx_drm_hdmi_component_ops [xilinx_hdmi_tx])
[ 13.176323] xilinx-hdmi-rx a0000000.v_hdmi_rx_ss: hdmi rx audio initialized
[ 13.226920] xilinx-hdmi-rx a0000000.v_hdmi_rx_ss: probe successful
[ 13.239197] xlnx_snd_card xlnx_snd_card.2.auto: i2s-hifi <-> snd-soc-dummy-dai mapping ok
[ 13.263962] xlnx_snd_card xlnx_snd_card.2.auto: a0000000.v_hdmi_rx_ss <-> snd-soc-dummy-dai mapping ok
[ 13.300536] xlnx_snd_card xlnx_snd_card.2.auto: xlnx-hdmi-snd-card-1 registered
[ 13.324766] xlnx-mixer a0070000.v_mix: fb1: frame buffer device
[ 13.339630] [drm] Initialized xlnx 1.0.0 20130509 for a0070000.v_mix on minor 1
[ 13.447568] VCU PLL: enable
[ 13.454850] xilinx-vcu xilinx-vcu: xvcu_probe: Probed successfully
[ 13.487544] al5d a0120000.al5d: l2 prefetch size:10526720 (bits), l2 color bitdepth:8
[ 13.488892] al5e a0100000.al5e: l2 prefetch size:10526720 (bits), l2 color bitdepth:8
[ 14.085381] pps pps0: new PPS source ptp0
[ 14.092664] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[ 14.102597] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.116298] macb ff0e0000.ethernet eth0: link up (1000/Full)
[ 15.125242] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.690367] Warning: Unknown drm_fourcc format code: 875713089
[ 20.413800] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.424688] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.435588] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.446453] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.460863] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.477707] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.492817] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.524893] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.534616] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.544486] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.554437] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.567644] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.594952] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 20.610571] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 22.386959] random: crng init done
[ 22.390352] random: 7 urandom warning(s) missed due to ratelimiting
[ 222.135994] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 234.238271] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 255.789526] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 299.867900] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 344.003272] ------------[ cut here ]------------
[ 344.007887] driver forgot to call drm_crtc_vblank_off()
[ 344.013148] WARNING: CPU: 3 PID: 3022 at drivers/gpu/drm/drm_atomic_helper.c:1000 drm_atomic_helper_commit_modeset_disables+0x3b0/0x3b8
[ 344.025303] Modules linked in: al5e(O) al5d(O) allegro(O) xlnx_vcu xlnx_vcu_clk xilinx_hdmi_tx(O) xilinx_hdmi_rx(O) xlnx_vcu_core xilinx_vphy(O) dp159(O) mali(O) uio_pdrv_genirq
[ 344.041131] CPU: 3 PID: 3022 Comm: modetest Tainted: G O 4.19.0-xilinx-v2019.1 #1
[ 344.049904] Hardware name: ZynqMP ZCU106 RevA (DT)
[ 344.054680] pstate: 60000005 (nZCv daif -PAN -UAO)
[ 344.059456] pc : drm_atomic_helper_commit_modeset_disables+0x3b0/0x3b8
[ 344.065975] lr : drm_atomic_helper_commit_modeset_disables+0x3b0/0x3b8
[ 344.072491] sp : ffffff8009433a00
[ 344.075790] x29: ffffff8009433a00 x28: ffffffc85eedf000
[ 344.081094] x27: ffffffc87b96cc00 x26: 0000000000000000
[ 344.086389] x25: 0000000000000038 x24: ffffff80091c785b
[ 344.091685] x23: ffffff8008d74270 x22: 0000000000000000
[ 344.096980] x21: ffffffc85b052800 x20: ffffffc87acb3090
[ 344.102284] x19: ffffffc85dabe280 x18: 0000000000000010
[ 344.107579] x17: 0000000000000000 x16: 0000000000000000
[ 344.112875] x15: ffffffffffffffff x14: ffffff8009148648
[ 344.118179] x13: ffffff80891e7f0f x12: ffffff80091e7f19
[ 344.123483] x11: ffffff800915a000 x10: ffffff80094336e0
[ 344.128787] x9 : 00000000ffffffd0 x8 : ffffff800854f180
[ 344.134091] x7 : 72635f6d7264206c x6 : 0000000000000220
[ 344.139386] x5 : 0000000000000001 x4 : 0000000000000000
[ 344.144681] x3 : 0000000000000000 x2 : ffffffffffffffff
[ 344.149977] x1 : 786b713a49afa000 x0 : 0000000000000000
[ 344.155272] Call trace:
[ 344.157706] drm_atomic_helper_commit_modeset_disables+0x3b0/0x3b8
[ 344.163877] drm_atomic_helper_commit_tail+0x20/0x78
[ 344.168825] commit_tail+0x74/0x78
[ 344.172211] drm_atomic_helper_commit+0xc8/0x140
[ 344.176813] drm_atomic_commit+0x48/0x58
[ 344.180727] drm_atomic_helper_set_config+0xa0/0xb0
[ 344.185588] drm_mode_setcrtc+0x144/0x5d8
[ 344.189582] drm_ioctl_kernel+0xb4/0x100
[ 344.193496] drm_ioctl+0x204/0x3a8
[ 344.196883] do_vfs_ioctl+0xb8/0x8a0
[ 344.200450] ksys_ioctl+0x44/0x90
[ 344.203748] __arm64_sys_ioctl+0x1c/0x28
[ 344.207656] el0_svc_common+0x84/0xd8
[ 344.211309] el0_svc_handler+0x68/0x80
[ 344.215042] el0_svc+0x8/0xc
[ 344.217905] ---[ end trace 987243167c0f6c84 ]---
[ 344.222526] Warning: Unknown drm_fourcc format code: 875713089
[ 347.616027] Warning: Unknown drm_fourcc format code: 875713089
[ 354.984910] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 381.135841] xlnx_formatter_pcm a0051000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 417.117893] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 471.579908] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 5132.249342] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 5149.887651] Warning: Unknown drm_fourcc format code: 875713089
[ 5171.551360] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 5582.945011] Warning: Unknown drm_fourcc format code: 875713089
[ 5591.308005] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 5612.771104] Warning: Unknown drm_fourcc format code: 875713089
[ 5612.800021] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[ 5612.807537] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[ 5621.032348] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[ 5621.039854] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[ 5621.047526] ------------[ cut here ]------------
[ 5621.052143] atomic remove_fb failed with -22
[ 5621.056446] WARNING: CPU: 0 PID: 51 at drivers/gpu/drm/drm_framebuffer.c:950 drm_framebuffer_remove+0x3a8/0x438
[ 5621.066516] Modules linked in: al5e(O) al5d(O) allegro(O) xlnx_vcu xlnx_vcu_clk xilinx_hdmi_tx(O) xilinx_hdmi_rx(O) xlnx_vcu_core xilinx_vphy(O) dp159(O) mali(O) uio_pdrv_genirq
[ 5621.082346] CPU: 0 PID: 51 Comm: kworker/0:1 Tainted: G W O 4.19.0-xilinx-v2019.1 #1
[ 5621.091205] Hardware name: ZynqMP ZCU106 RevA (DT)
[ 5621.095983] Workqueue: events drm_mode_rmfb_work_fn
[ 5621.100851] pstate: 40000005 (nZcv daif -PAN -UAO)
[ 5621.105625] pc : drm_framebuffer_remove+0x3a8/0x438
[ 5621.110486] lr : drm_framebuffer_remove+0x3a8/0x438
[ 5621.115346] sp : ffffff8009383ce0
[ 5621.118645] x29: ffffff8009383ce0 x28: ffffffc85b052b80
[ 5621.123949] x27: ffffffc85b052b88 x26: 00000000ffffffea
[ 5621.129253] x25: 0000000000000001 x24: ffffffc85b052800
[ 5621.134557] x23: ffffff8009148648 x22: 0000000000000000
[ 5621.139852] x21: ffffff8009383d50 x20: ffffffc85a5d3d00
[ 5621.145156] x19: ffffffc85d986300 x18: 0000000000000010
[ 5621.150452] x17: 0000000000000000 x16: 0000000000000000
[ 5621.155747] x15: ffffffffffffffff x14: ffffff8009148648
[ 5621.161051] x13: ffffff80891e7f0f x12: ffffff80091e7f18
[ 5621.166355] x11: ffffff800915a000 x10: ffffff80093839c0
[ 5621.171650] x9 : 00000000ffffffd0 x8 : ffffff800854f180
[ 5621.176954] x7 : 2064656c69616620 x6 : ffffffc87ff4c998
[ 5621.182249] x5 : ffffffc87ff4c998 x4 : 0000000000000000
[ 5621.187545] x3 : ffffffc87ff535e8 x2 : ffffffc87ff4c998
[ 5621.192840] x1 : 786b713a49afa000 x0 : 0000000000000000
[ 5621.198136] Call trace:
[ 5621.200569] drm_framebuffer_remove+0x3a8/0x438
[ 5621.205082] drm_mode_rmfb_work_fn+0x40/0x58
[ 5621.209337] process_one_work+0x1e4/0x340
[ 5621.213337] worker_thread+0x248/0x488
[ 5621.217072] kthread+0x124/0x128
[ 5621.220292] ret_from_fork+0x10/0x18
[ 5621.223849] ---[ end trace 987243167c0f6c85 ]---
[ 5622.906567] xlnx_formatter_pcm a0052000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
Tags (2)
Re: No Video caused by flip_done timed out on VCU TRD 2019.1
To help the support I have enable DEBUG into hdmi-module kernel drm modules
and this is what I got when the gstreamer command is called with resolution changes in stream
I have add a BUG_ON directive in the kernel source to know what is the called stack when  flip_done timed out occurs
(it's not part of the real Xilinx code)
[  231.465040] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: TX Bridge Unlocked Callback
[  231.465048] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: TX Video Bridge Underflow
[  231.465115] call vpss.set_input(1920,1080,0x100a)
[  231.465185] call vpss.set_output(1920,1080,0x100a)
[  231.474570] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_detect() = connected
[  231.474579] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_get_modes
[  231.546801] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: EDID shows HDMI sink is connected, setting stream type to HDMI
[  231.547202] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_get_modes() done
[  231.547369] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547377] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547383] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547389] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547397] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547405] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547413] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547421] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547429] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547437] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547445] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547452] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547469] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547486] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547502] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547519] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547535] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547552] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547569] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547574] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547578] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547585] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547591] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547608] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547624] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547631] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547637] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547642] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547646] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547651] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547655] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547660] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547664] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547669] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547673] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_INTERLACE, divide mode->vdisplay 540
[  231.547690] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547694] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_INTERLACE, divide mode->vdisplay 540
[  231.547712] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547716] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_INTERLACE, divide mode->vdisplay 540
[  231.547733] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547737] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_INTERLACE, divide mode->vdisplay 540
[  231.547754] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547758] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_INTERLACE, divide mode->vdisplay 288
[  231.547763] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_DBLCLK, multiply pixel_clk by 2, New pixel clock 27000, refresh rate = 50
[  231.547780] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547784] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_INTERLACE, divide mode->vdisplay 240
[  231.547789] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_DBLCLK, multiply pixel_clk by 2, New pixel clock 27000, refresh rate = 60
[  231.547806] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547810] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_INTERLACE, divide mode->vdisplay 288
[  231.547815] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_DBLCLK, multiply pixel_clk by 2, New pixel clock 27000, refresh rate = 50
[  231.547832] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547836] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_INTERLACE, divide mode->vdisplay 240
[  231.547841] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_DBLCLK, multiply pixel_clk by 2, New pixel clock 27000, refresh rate = 60
[  231.547861] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547865] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_INTERLACE, divide mode->vdisplay 540
[  231.547882] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547886] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_INTERLACE, divide mode->vdisplay 240
[  231.547890] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_DBLCLK, multiply pixel_clk by 2, New pixel clock 27028, refresh rate = 60
[  231.547907] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: xlnx_drm_hdmi_connector_mode_valid
[  231.547911] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_INTERLACE, divide mode->vdisplay 240
[  231.547915] xlnx-drm-hdmi a0020000.v_hdmi_tx_ss: For DRM_MODE_FLAG_DBLCLK, multiply pixel_clk by 2, New pixel clock 27028, refresh rate = 60
[  232.064978] xlnx_formatter_pcm a00a1000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[  241.637496] [drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [CRTC:34:crtc-0] flip_done timed out
[  241.637529] ------------[ cut here ]------------
[  241.637532] kernel BUG at drivers/gpu/drm/drm_atomic_helper.c:2025!
[  241.637536] Internal error: Oops - BUG: 0 [#1] SMP
[  241.637538] Modules linked in: al5e(O) al5d(O) allegro(O) xlnx_vcu xlnx_vcu_clk xilinx_hdmi_rx(O) xilinx_hdmi_tx(O) xlnx_vcu_core dp159(O) xilinx_vphy(O) mali(O) uio_pdrv_genirq
[  241.637567] CPU: 1 PID: 1722 Comm: kworker/1:3 Tainted: G           O      4.19.0 #1
[  241.637569] Hardware name: xlnx,zynqmp (DT)
[  241.637577] Workqueue: events drm_mode_rmfb_work_fn
[  241.637582] pstate: 60000005 (nZCv daif -PAN -UAO)
[  241.637588] pc : drm_atomic_helper_wait_for_dependencies+0x224/0x228
[  241.637592] lr : drm_atomic_helper_wait_for_dependencies+0x1bc/0x228
[  241.637594] sp : ffffff800c0e3c20
[  241.637596] x29: ffffff800c0e3c20 x28: ffffffc012b38380
[  241.637601] x27: ffffffc012b38388 x26: 0000000000000000
[  241.637606] x25: ffffffc00f6b8300 x24: ffffff8008dd0c18
[  241.637610] x23: ffffff8008dd0c40 x22: 0000000000000038
[  241.637615] x21: ffffffc012e53890 x20: 0000000000000001
[  241.637620] x19: ffffffc012be9d80 x18: 00000000fffffff0
[  241.637624] x17: 0000000000000000 x16: 0000000000000000
[  241.637629] x15: ffffff80091ca758 x14: 6f645f70696c6620
[  241.637633] x13: 5d302d637472633a x12: 34333a435452435b
[  241.637638] x11: 202a524f5252452a x10: 205d736569636e65
[  241.637642] x9 : 0000000000000000 x8 : 0000000000000000
[  241.637647] x7 : ffffff8009281000 x6 : ffffffc07fe7f980
[  241.637652] x5 : ffffffc07fe7f980 x4 : 0000000000000000
[  241.637656] x3 : ffffffc07fe865e0 x2 : 27800919312c6800
[  241.637661] x1 : ffffffc012b38000 x0 : 0000000000000001
[  241.637667] Process kworker/1:3 (pid: 1722, stack limit = 0x00000000d6676a9c)
[  241.637669] Call trace:
[  241.637674]  drm_atomic_helper_wait_for_dependencies+0x224/0x228
[  241.637678]  commit_tail+0x30/0x78
[  241.637682]  drm_atomic_helper_commit+0xc8/0x140
[  241.637686]  drm_atomic_commit+0x48/0x58
[  241.637691]  drm_framebuffer_remove+0x37c/0x438
[  241.637695]  drm_mode_rmfb_work_fn+0x40/0x58
[  241.637701]  process_one_work+0x1e4/0x340
[  241.637706]  worker_thread+0x248/0x488
[  241.637710]  kthread+0x124/0x128
[  241.637714]  ret_from_fork+0x10/0x18
[  241.637720] Code: aa1803e0 f94026a2 9400b081 17ffffb6 (d4210000)
[  241.637724] ---[ end trace d34934056901ef97 ]---
root@KDS-DEC1
Scholar watari
Hi @ericzerbib
What monitor do you use ?
Wolud you share model name ?
Best regards,
It's a LG monitor 27UD68P, if it can help
Scholar watari
Hi @ericzerbib
It's an interesting and a little funny behaviour for DRM in your log file with DEBUG option.
What resolution, framerate and interlace or progressive do you input on your device ?
Also, do you use certified HDMI cable ?
Best regards,
Yes of course
- cable is HDMI certified
- 4K as in input  then I change to a 1080p resolution, I want to insist here I can run multiple times the stream 4K, but when I change/switch to a stream with 1080p then the error occurs and I need to reboot the board. Same way when I boot and I choose a stream set to 1080p I can stop start multiple times the stream and the video continue to play but if i switch to 4k then the error occurs
Scholar watari
Hi @ericzerbib
Could you share debug log which is generated by adding the following option on gstreamer ?
gst-lauch-1.0 --gst-debug-no-color --gst-debug-level=4 .....
BTW, did you connect HDMI source device on HDMI Rx connector ?
If yes, what resolution, framerate and interlace/progressive do you input ?
I'm facing similer issue in HDMI Rx side.
In my case, I only want to know how to control HDMI Rx via v4l2-ctl, media-ctl, modetest and so on.
Best regards.
I'm not using the HDMI Rx connector I get my stream from the net and display it on the Monitor. when I mention input in my previous discussion it's about the resolution comming from the encoded stream.
attached log
Scholar watari
Hi @ericzerbib
After confirmation of log, I found a funny result on line 1025 of log file.
0:00:01.364314195 4345 0x7f74044400 INFO GST_EVENT gstevent.c:814:gst_event_new_caps: creating caps event video/x-raw(memory:GLMemory), format=(string)RGBA, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)sRGB, framerate=(fraction)0/1
Would you add framerate setting as capability setting on this pipeline, if possible ?
Best regards,
I was thinking the the problem is more oriented DRM
The actual pipeline command is working many and many time without specifying the caps, in any capfilter. The beauty of this pipeline command is that it doesn't need any pre-parsing of the content of the stream, according to the stream it play it. Another point is if i need to add framerate at which point of the gst command is it expected:?
- after omxh264dec pluggin ?
Acutally I have more suspicion ont the modeset command that fails sometimes if I run it twice. When the problem occur it was while I'm playing a 4k stream and I set mode with modeset to 1080p. And when It happens the video TV stay with no signal.
A new error occurs when I m into the streaming command running and then I run the modeset command
[ 7.877160] macb ff0e0000.ethernet eth0: link up (1000/Full)
[ 7.877179] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.861707] audit: type=1006 audit(1561374113.643:4): pid=3670 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ 18.336816] audit: type=1006 audit(1561374114.115:5): pid=3665 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
[ 38.188370] audit: type=1006 audit(1561374133.967:6): pid=4119 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[ 72.086111] Warning: Unknown drm_fourcc format code: 875713089
[ 81.582046] audit: type=1006 audit(1561374177.367:7): pid=4129 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=4 res=1
[ 97.058055] xlnx_formatter_pcm a00a1000.audio_formatter: stream 0 : format = 1 mode = 3 ch_limit = 2
[ 98.512350] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[ 195.575285] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[ 222.779746] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[ 712.933809] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[ 741.023912] ------------[ cut here ]------------
[ 741.023916] driver forgot to call drm_crtc_vblank_off()
[ 741.023962] WARNING: CPU: 1 PID: 4318 at drivers/gpu/drm/drm_atomic_helper.c:1000 drm_atomic_helper_commit_modeset_disables+0x3b0/0x3b8
[ 741.023964] Modules linked in: al5e(O) al5d(O) allegro(O) xlnx_vcu xlnx_vcu_clk dp159(O) xilinx_hdmi_tx(O) xilinx_hdmi_rx(O) xlnx_vcu_core xilinx_vphy(O) mali(O) uio_pdrv_genirq
[ 741.023992] CPU: 1 PID: 4318 Comm: modetest Tainted: G O 4.19.0 #1
[ 741.023994] Hardware name: xlnx,zynqmp (DT)
[ 741.023998] pstate: 40000005 (nZcv daif -PAN -UAO)
[ 741.024002] pc : drm_atomic_helper_commit_modeset_disables+0x3b0/0x3b8
[ 741.024006] lr : drm_atomic_helper_commit_modeset_disables+0x3b0/0x3b8
[ 741.024008] sp : ffffff80094eba00
[ 741.024010] x29: ffffff80094eba00 x28: ffffffc0115b6800
[ 741.024015] x27: ffffffc011ebe400 x26: 0000000000000000
[ 741.024019] x25: 0000000000000038 x24: ffffff800923605b
[ 741.024024] x23: ffffff8008dd1688 x22: 0000000000000000
[ 741.024028] x21: ffffffc00f08a000 x20: ffffffc0127a4890
[ 741.024033] x19: ffffffc012615800 x18: 00000000fffffff0
[ 741.024038] x17: 0000000000000001 x16: 0000000000000007
[ 741.024042] x15: ffffff80091ca758 x14: ffffff8009282a10
[ 741.024047] x13: 0000000000000000 x12: ffffff8009282000
[ 741.024051] x11: ffffff80091ca000 x10: ffffff8009282068
[ 741.024056] x9 : 0000000000000000 x8 : 0000000000000000
[ 741.024060] x7 : ffffff8009282000 x6 : 00000000000001c4
[ 741.024064] x5 : 0000000000000001 x4 : ffffffc07fe7f978
[ 741.024069] x3 : ffffffc07fe7f978 x2 : 0000000000000007
[ 741.024073] x1 : 27800919312c6800 x0 : 0000000000000000
[ 741.024078] Call trace:
[ 741.024082] drm_atomic_helper_commit_modeset_disables+0x3b0/0x3b8
[ 741.024086] drm_atomic_helper_commit_tail+0x20/0x78
[ 741.024090] commit_tail+0x74/0x78
[ 741.024093] drm_atomic_helper_commit+0xc8/0x140
[ 741.024098] drm_atomic_commit+0x48/0x58
[ 741.024102] drm_atomic_helper_set_config+0xa0/0xb0
[ 741.024107] drm_mode_setcrtc+0x144/0x5d8
[ 741.024111] drm_ioctl_kernel+0xb4/0x100
[ 741.024114] drm_ioctl+0x204/0x3a8
[ 741.024119] do_vfs_ioctl+0xb8/0x8a0
[ 741.024123] ksys_ioctl+0x44/0x90
[ 741.024127] __arm64_sys_ioctl+0x1c/0x28
[ 741.024132] el0_svc_common+0x84/0xd8
[ 741.024136] el0_svc_handler+0x68/0x80
[ 741.024139] el0_svc+0x8/0xc
[ 741.024142] ---[ end trace a0a8c12f77e1f4b5 ]---
[ 741.024150] Warning: Unknown drm_fourcc format code: 875713089
[ 765.340371] Warning: Unknown drm_fourcc format code: 875713089
[ 800.923471] Warning: Unknown drm_fourcc format code: 875713089
[ 807.854647] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[ 829.045487] Warning: Unknown drm_fourcc format code: 875713089
[ 8116.242973] Warning: Unknown drm_fourcc format code: 875713089
[ 8117.966239] Warning: Unknown drm_fourcc format code: 875713089
[ 8412.525440] Warning: Unknown drm_fourcc format code: 875713089
[ 8527.133470] Warning: Unknown drm_fourcc format code: 875713089
[ 8574.012571] audit: type=1006 audit(1561382669.770:8): pid=5007 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=5 res=1
[10058.589435] Warning: Unknown drm_fourcc format code: 875713089
[10059.711818] Warning: Unknown drm_fourcc format code: 875713089
[13093.866500] Warning: Unknown drm_fourcc format code: 875713089
[13684.229577] Warning: Unknown drm_fourcc format code: 875713089
[13686.171143] Warning: Unknown drm_fourcc format code: 875713089
[13706.393601] Warning: Unknown drm_fourcc format code: 875713089
[13714.810061] Warning: Unknown drm_fourcc format code: 875713089
[13726.504164] Warning: Unknown drm_fourcc format code: 875713089
[13796.136475] Warning: Unknown drm_fourcc format code: 875713089
[13796.159818] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[13796.159845] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[13797.051228] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[13797.051244] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[13797.051248] ------------[ cut here ]------------
[13797.051250] atomic remove_fb failed with -22
[13797.051296] WARNING: CPU: 0 PID: 1731 at drivers/gpu/drm/drm_framebuffer.c:950 drm_framebuffer_remove+0x3a8/0x438
[13797.051298] Modules linked in: al5e(O) al5d(O) allegro(O) xlnx_vcu xlnx_vcu_clk dp159(O) xilinx_hdmi_tx(O) xilinx_hdmi_rx(O) xlnx_vcu_core xilinx_vphy(O) mali(O) uio_pdrv_genirq
[13797.051327] CPU: 0 PID: 1731 Comm: kworker/0:2 Tainted: G W O 4.19.0 #1
[13797.051329] Hardware name: xlnx,zynqmp (DT)
[13797.051336] Workqueue: events drm_mode_rmfb_work_fn
[13797.051341] pstate: 40000005 (nZcv daif -PAN -UAO)
[13797.051346] pc : drm_framebuffer_remove+0x3a8/0x438
[13797.051350] lr : drm_framebuffer_remove+0x3a8/0x438
[13797.051352] sp : ffffff800c26bce0
[13797.051354] x29: ffffff800c26bce0 x28: ffffffc00f08a380
[13797.051359] x27: ffffffc00f08a388 x26: 00000000ffffffea
[13797.051363] x25: 0000000000000001 x24: ffffffc00f08a000
[13797.051368] x23: ffffff80091b8648 x22: 0000000000000000
[13797.051372] x21: ffffff800c26bd50 x20: ffffffc00f6cb100
[13797.051377] x19: ffffffc00f485300 x18: 00000000fffffff0
[13797.051381] x17: 0000000000000001 x16: 0000000000000007
[13797.051386] x15: ffffff80091ca758 x14: ffffff8009282a10
[13797.051390] x13: 0000000000000000 x12: ffffff8009282000
[13797.051395] x11: ffffff80091ca000 x10: ffffff8009282068
[13797.051399] x9 : 0000000000000000 x8 : 0000000000000000
[13797.051404] x7 : ffffff8009282000 x6 : 0000000000000205
[13797.051408] x5 : 0000000000000001 x4 : ffffffc07fe69978
[13797.051412] x3 : ffffffc07fe69978 x2 : 0000000000000007
[13797.051417] x1 : 27800919312c6800 x0 : 0000000000000000
[13797.051421] Call trace:
[13797.051426] drm_framebuffer_remove+0x3a8/0x438
[13797.051431] drm_mode_rmfb_work_fn+0x40/0x58
[13797.051437] process_one_work+0x1e4/0x340
[13797.051441] worker_thread+0x248/0x488
[13797.051445] kthread+0x124/0x128
[13797.051449] ret_from_fork+0x10/0x18
[13797.051452] ---[ end trace a0a8c12f77e1f4b6 ]---
[13827.136351] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[13827.136359] [drm:xlnx_mix_plane_atomic_update] *ERROR* failed to mode-set a plane
[13846.029132] [drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [CRTC:34:crtc-0] flip_done timed out
[13856.269160] [drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [PLANE:30:plane-0] flip_done timed out
[13866.509143] [drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [PLANE:32:plane-2] flip_done timed out
[13866.509163] [drm:is_window_valid] *ERROR* Requested plane dimensions can't be set
[13866.509168] [drm:xlnx_mix_plane_atomic_update] *ERROR* failed to mode-set a plane
root@KDS-DEC10-10112:~#
Since you are seeing problems with modetest, this sounds more like an issue with the HDMI Link.  You can look at the status of the HDMI Link by using the following:
$ cat /sys/devices/platform/amba_pl@0/a0020000.v_hdmi_tx_ss/hdmi_info
$ cat /sys/devices/platform/amba_pl@0/a0020000.v_hdmi_tx_ss/vphy_info
$ cat /sys/devices/platform/amba_pl@0/a0020000.v_hdmi_tx_ss/hdmi_log
$ cat /sys/devices/platform/amba_pl@0/a0020000.v_hdmi_tx_ss/vphy_log
It would also be good to see the output of modetest:
modetest -D a0070000.v_mix
Chris
Video Design Hub | Embedded SW Support
Hi chrisar
thanks for your support
When It's happened here is the output of the hdmi status
root@zcu106_vcu_trd:/media/card# ./hdmi_out_status_brief.sh
Stream Info
Color Format: RGB
Color Depth: 8
Pixels Per Clock: 2
Mode: Progressive
Frame Rate: 60Hz
Resolution: 1920x1080 [Custom Mode]
Pixel Clock: 148500000
Stream Timing
HSYNC Timing: hav=1920, hfp=88, hsw=44(hsp=1), hbp=148, htot=2200
VSYNC Timing: vav=1080, vfp=04, vsw=05(vsp=0), vbp=036, vtot=1125
Tx Info
TX Mode - HDMI
HDMI Video Mask is Disabled
Scrambled: 0
Sample rate: 1
Audio channels: 0
TX: QPLL0
RX: CPLL
TX state: idle
RX state: idle
QPLL0 settings
M : 1 - N : 80 - D : 8
CPLL settings
M : 0 - N1 : 0 - N2 : 0 - D : 0
RX MMCM settings
Mult : 0 - Div : 0 - Clk0Div : 0 - Clk1Div : 0 - Clk2Div : 0
TX MMCM settings
Mult : 10 - Div : 1 - Clk0Div : 20 - Clk1Div : 10 - Clk2Div : 20
DRU Settings
Version : 7
DRU is disabled
Tx Ref Clk: 148504576 Hz
HDMI TX log
TX Audio Unmuted
VID Bridge Unlocked
TX Set Stream, with video mode (191)
TX Stream is Down
TX Audio Unmuted
TX Stream is Up
TX Audio Unmuted
VPHY log
TX frequency event
QPLL lost lock
TX frequency event
TX timer event
TX MMCM reconfig done
QPLL reconfig done
GT TX reconfig start
GT TX reconfig done
TX MMCM lock
QPLL lock
TX reset done
TX alignment done
For info the script that I run is this
root@zcu106_vcu_trd:/media/card# cat ./hdmi_out_status_brief.sh
The condition to reprocduce is simple
1  - Set mode for 1080p with modetest
root@zcu106_vcu_trd:/media/card# modetest -M xlnx -D a0070000.v_mix -s 40:1920x1080-60@AR24
setting mode 1920x1080-60Hz@AR24 on connectors 40, crtc 38
2) Play 1080p stream in another terminal
GST_DEBUG=3 gst-launch-1.0 --no-fault rtspsrc location=rtsp://192.168.0.19:554/stream latency=10 name=demux demux. ! rtph265depay ! h265parse ! queue max-size-buffers=0 max-size-bytes=0 ! omxh265dec internal-entropy-buffers=5 low-latency=0 ! queue max-size-buffers=0 max-size-bytes=0 ! kmssink bus-id=a0070000.v_mix max-lateness=20000000 plane-id=30 qos=true sync=false demux. ! rtpmp4adepay ! faad ! audioconvert ! audioresample ! audio/x-raw, rate=48000, channnels=2, format=S24_32LE ! alsasink device=hw:2,0
3) Stop the play from step 2) with ctrl+C
4) Play the 4k stream (IP different in url location)
GST_DEBUG=3 gst-launch-1.0 --no-fault rtspsrc location=rtsp://192.168.68.181:554/stream latency=10 name=demux demux. ! rtph264depay ! h264parse ! queue max-size-buffers=0 max-size-bytes=0 ! omxh264dec internal-entropy-buffers=5 low-latency=0 ! queue max-size-buffers=0 max-size-bytes=0 ! kmssink bus-id=a0070000.v_mix max-lateness=20000000 plane-id=30 qos=true sync=false demux. ! rtpmp4adepay ! faad ! audioconvert ! audioresample ! audio/x-raw, rate=48000, channnels=2, format=S24_32LE ! alsasink device=hw:2,0
5) Set the mode test to 4k
root@zcu106_vcu_trd:~# modetest -D a0070000.v_mix -s 40:3840x2160-60@AR24 -w 36:"alpha":0
setting mode 3840x2160-60Hz@AR24 on connectors 40, crtc 38
At this point the screen is loosing sync and you see in the dmesg the previous mentioned errors
even if I retry to set the mode by modetest another time I get this error
failed to set mode: Function not implemented
I forgot the output of this command when the problem appears
Encoders:
id      crtc    type    possible crtcs  possible clones
39      38      TMDS    0x00000001      0x00000000
Connectors:
id      encoder status          name            size (mm)       modes   encoders
40      39      connected       HDMI-A-1        600x340         38      39
  modes:
        name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
  3840x2160 60 3840 4016 4104 4400 2160 2168 2178 2250 594000 flags: phsync, pvsync; type: preferred, driver
  3840x2160 60 3840 4016 4104 4400 2160 2168 2178 2250 594000 flags: phsync, pvsync; type: driver
  3840x2160 60 3840 4016 4104 4400 2160 2168 2178 2250 593407 flags: phsync, pvsync; type: driver
  3840x2160 50 3840 4896 4984 5280 2160 2168 2178 2250 594000 flags: phsync, pvsync; type: driver
  3840x2160 30 3840 4016 4104 4400 2160 2168 2178 2250 297000 flags: phsync, nvsync; type: driver
  3840x2160 30 3840 4016 4104 4400 2160 2168 2178 2250 297000 flags: phsync, pvsync; type: driver
  3840x2160 30 3840 4016 4104 4400 2160 2168 2178 2250 296703 flags: phsync, pvsync; type: driver
  3840x2160 25 3840 4896 4984 5280 2160 2168 2178 2250 297000 flags: phsync, pvsync; type: driver
  3840x2160 24 3840 5116 5204 5500 2160 2168 2178 2250 297000 flags: phsync, pvsync; type: driver
  3840x2160 24 3840 5116 5204 5500 2160 2168 2178 2250 296703 flags: phsync, pvsync; type: driver
  1920x1080 60 1920 2008 2052 2200 1080 1084 1089 1125 148500 flags: phsync, nvsync; type: driver
  1920x1080 60 1920 2008 2052 2200 1080 1084 1089 1125 148500 flags: phsync, pvsync; type: driver
  1920x1080 60 1920 2008 2052 2200 1080 1084 1089 1125 148352 flags: phsync, pvsync; type: driver
  1920x1080 30 1920 2008 2052 2200 1080 1084 1089 1125 74250 flags: phsync, pvsync; type: driver
  1920x1080 30 1920 2008 2052 2200 1080 1084 1089 1125 74176 flags: phsync, pvsync; type: driver
  1920x1080 24 1920 2558 2602 2750 1080 1084 1089 1125 74250 flags: phsync, pvsync; type: driver
  1920x1080 24 1920 2558 2602 2750 1080 1084 1089 1125 74176 flags: phsync, pvsync; type: driver
  1600x900 60 1600 1624 1704 1800 900 901 904 1000 108000 flags: phsync, pvsync; type: driver
  1280x1024 60 1280 1328 1440 1688 1024 1025 1028 1066 108000 flags: phsync, pvsync; type: driver
  1920x1080i 60 1920 2008 2052 2200 540 1084 1094 1125 74250 flags: phsync, pvsync, interlace; type: driver
  1920x1080i 60 1920 2008 2052 2200 540 1084 1094 1125 74176 flags: phsync, pvsync, interlace; type: driver
  1280x800 60 1280 1328 1360 1440 800 803 809 823 71000 flags: phsync, nvsync; type: driver
  1152x864 60 1152 1216 1336 1520 864 865 868 895 81579 flags: nhsync, pvsync; type:
  1280x720 60 1280 1390 1430 1650 720 725 730 750 74250 flags: phsync, pvsync; type: driver
  1280x720 60 1280 1390 1430 1650 720 725 730 750 74176 flags: phsync, pvsync; type: driver
  1024x768 60 1024 1048 1184 1344 768 771 777 806 65000 flags: nhsync, nvsync; type: driver
  800x600 60 800 840 968 1056 600 601 605 628 40000 flags: phsync, pvsync; type: driver
  720x480 60 720 736 798 858 480 489 495 525 27027 flags: nhsync, nvsync; type: driver
  720x480 60 720 736 798 858 480 489 495 525 27000 flags: nhsync, nvsync; type: driver
  640x480 60 640 656 752 800 480 490 492 525 25200 flags: nhsync, nvsync; type: driver
  640x480 60 640 656 752 800 480 490 492 525 25175 flags: nhsync, nvsync; type: driver
  props:
        1 EDID:
                flags: immutable blob
                blobs:
                value:
                        00ffffffffffff001e6d085b73600400
                        031a0103803c2278ea3035a7554ea326
                        0f50542108007140818081c0a9c0d1c0
                        81000101010108e80030f2705a80b058
                        8a0058542100001e04740030f2705a80
                        b0588a0058542100001a000000fd0038
                        3d1e873c000a202020202020000000fc
                        004c4720556c7472612048440a200139
                        020330714d902220050403020161605d
                        5e5f230907076d030c001000b83c2000
                        6001020367d85dc401788003e30f0003
                        023a801871382d40582c450058542100
                        001a0000000000000000000000000000
                        00000000000000000000000000000000
                        00000000000000000000000000000026
        2 DPMS:
                flags: enum
                enums: On=0 Standby=1 Suspend=2 Off=3
                value: 0
        5 link-status:
                flags: enum
                enums: Good=0 Bad=1
                value: 0
        6 non-desktop:
                flags: immutable range
                values: 0 1
                value: 0
        19 CRTC_ID:
                flags: object
                value: 38
CRTCs:
id      fb      pos     size
38      0       (0,0)   (1920x1080)
  props:
        20 ACTIVE:
                flags: range
                values: 0 1
                value: 1
        21 MODE_ID:
                flags: blob
                blobs:
                value:
                        144402008007d8070408980800003804
                        3c044104650400003c00000009000000
                        40000000313932307831303830000000
                        00000000
        18 OUT_FENCE_PTR:
                flags: range
                values: 0 18446744073709551615
                value: 0
Planes:
id      crtc    fb      CRTC x,y        x,y     gamma size      possible crtcs
30      38      103     0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                flags: immutable enum
                enums: Overlay=0 Primary=1 Cursor=2
                value: 0
        16 FB_ID:
                flags: object
                value: 103
        17 IN_FENCE_FD:
                flags: signed range
                values: -1 2147483647
                value: -1
        19 CRTC_ID:
                flags: object
                value: 38
        12 CRTC_X:
                flags: signed range
                values: -2147483648 2147483647
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                values: 0 2147483647
                value: 3840
        15 CRTC_H:
                flags: range
                value: 2160
        8 SRC_X:
                flags: range
                values: 0 4294967295
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 251658240
        11 SRC_H:
                flags: range
                value: 141557760
31      0       0       0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
32      0       0       0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
33      0       0       0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
34      0       0       0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
35      0       0       0,0             0,0     0               0x00000001
  formats: NV12
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
36      0       0       0,0             0,0     0               0x00000001
  formats: AR24
  props:
        7 type:
                value: 1
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 1920
        15 CRTC_H:
                flags: range
                value: 1080
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 125829120
        11 SRC_H:
                flags: range
                value: 70778880
        29 alpha:
                flags: range
                values: 0 256
                value: 0
37      0       0       0,0             0,0     0               0x00000001
  formats: BG24
  props:
        7 type:
                value: 0
        16 FB_ID:
                flags: object
                value: 0
        17 IN_FENCE_FD:
                flags: signed range
                value: -1
        19 CRTC_ID:
                flags: object
                value: 0
        12 CRTC_X:
                flags: signed range
                value: 0
        13 CRTC_Y:
                flags: signed range
                value: 0
        14 CRTC_W:
                flags: range
                value: 0
        15 CRTC_H:
                flags: range
                value: 0
        8 SRC_X:
                flags: range
                value: 0
        9 SRC_Y:
                flags: range
                value: 0
        10 SRC_W:
                flags: range
                value: 0
        11 SRC_H:
                flags: range
                value: 0
Frame buffers:
id      size    pitch
I tried to reproduce the problem by just switching resolution with modetest, and it always worked on my NEC MultiSync EA 275 UHD without any problems.
Chris
I don't know what to say !
I don't think the issue is related to the type of the Monitor
But if you can't reproduce
close the case, I have found a work arround by sleeping a while between two running instance of modetest
Participant silat14
Hello I got the same error when I run the modetest, how could you fix it?I still can not changing the resolution. Thanks in advance.
I thnik you need to be sure that modetest is not run twice at the same time
that is to say in the the documentation it's indicated to run modetest in background task as :
modetest .... &
but modetest is also waiting inside the program to a press a key (getchar)
so you need to press a key and the modetest program is exiting properly
Participant silat14
Hello again,
First of all,thank you for your answer, I checked but modetest wasn't run twice in background.
Hello
- Do you use a LG monitor ?
- Do you use gstreamer sometimes with 1080p stream and sometimes with 4k ?
- I just remark that "chrisar" didn't fully tryied to reproduce the case how I described it, yes chrisar for me it works also by just switching resolution with modetest
the problem is when you use in combination gstreamter as I describes upper .
Let me remove the response of "chrisar" as "acceptable solution" do you  agree ?
Participant silat14
My monitor is DELL U2715H,
No,now I just use 1080p 60fps video out signal,
1080p 60fps video out signal goes to the board, and the video out of board goes to HDLink Pro(BlackMagic design) Converter. Then converter's HDMI output goes to the DELL Monitor. However when I run this modetest command :
Modetest -M xlnx -D a0070000.v_mix -s 36:1920x1080-60@YUYV
I can only see a blue screen. Thanks in advance.
The blue screen is expected.  This shows that the HDMI Tx link from the ZCU106 to the HDMI Monitor is working.  Most monitors will show the resolution in the On Screen Display controls, so that you can verify that it has linked at the correct resolution.
Once you have the blue screen you should be able to launch your GStreamer pipeline.
Chris
Participant silat14
I am trying to implement HD-SDI project(Zynq UltraScale+ MPSoC VCU TRD 2018.3 - SDI Video Capture and SDI Display project). Is it also correct for my case?
I also have another problem about creating DSA file (link).
May it be the cause of the problem?
Thanks in advance.
@ericzerbib
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
Hello
thanks for yor remark but as I mention upper int this trhead I see the problem here is not resolved, while the main answer of this thread has been given by
