Spartan7 MIPI RX interface based on xapp894
 I got the error message "Message cannot exceed 60,000 characters." here. So I put my question into a pdf. Please see it and give me suggestions.
Re: Spartan7 MIPI RX interface based on xapp894
1. Already answered your questions.
"2. Why I MIPI D-phy rx can't receive data in situation 1 and 2"
Situation 1 & 2 in your simulation are expected result.
On situation 1, D-PHY RX will initialized the IP correctly (INIT_DONE=1), since LP-11 is observed on the MIPI D-PHY clock and data lanes for more than TINIT.
On situation 2, D-PHY RX will not be able to complete initialization process (INIT_DONE=0), since RX IP cannot observed LP-11.
On situation 1, D-PHY RX cannot receive data sent by TX because MIPI D-PHY RX cannot detect LP-mode --> HS-mode transition signal. (which is LP-11, LP-01, LP-00)
"1. any suggestions to make my design work on PCB?"
As mentioned above using external DPHY devices is my suggestion.
If you wish resistor network you need to do some debugging to find the root-cause.
For example, check if your XC7S25 input pin has a stable LP-11 supplied during initialization. Check if the LP-11 level is correct. If LP-11 is not correctly supplied, MIPI RX initialization will not complete.
2. Asked you to check MIPI spec, since you do not understand that LP-11 is required by MIPI RX to complete initialization process.
Hello @jerry.yau
>So my question is:
>1. Any suggestions to make my design work on PCB?
1. For 7-series FPGA I would suggest to use External D-PHY devices
    http://www.meticom.com/page2/page17/MC20901.html
    http://www.meticom.com/page2/page20/MC20902.html
2. Situation 1 & 2 are expected result.
some suggestions ( not related to your question )
1. MIPI is a Video IP. Please post MIPI related question to Video board
    https://forums.xilinx.com/t5/Video/bd-p/DSPTOOL
2. Please check MIPI D-PHY specification on the following URL to understand MIPI protocol.
    https://members.mipi.org/wg/All-Members/document/folder/8354
Thanks & regards
Leo
HI @karnanl
Do you have any update on this topic? Was @karnanl 's reply enough for you?
Thanks and Regards,
  No. I hope you can run MIPI DPHY simulation to know my question and give me the answer directly. Not just tell me to read MIPI spec.
The simulation environment comes from XIlinx vivado.
Jerry
OK. Thanks
