Participant liufengwuhen
State change failed (Zynq UltraScale+ MPSoC VCU TRD 2018.3 - HDMI Video Capture)
    When I use demo of  MPSoC VCU TRD 2018.3, some error happens. And I use computer's HDMI out to connecting the ZCU106 HDMI Rx port. Am I right?
state_change_failed.jpgSTATE CHANGE FAILEDxmedia-ctl.jpgxmedia ctl log
Tags (3)
Re: State change failed (Zynq UltraScale+ MPSoC VCU TRD 2018.3 - HDMI Video Capture)
Hi @liufengwuhen ,
Make sure you are using the patch from AR#71798 as they might solve the issue you have.
Florent
The image.ub is download in rdf0428-zcu106-vcu-trd-2018-3\images\vcu_trd directory. Am I need to compile the petalinux again?
HI @liufengwuhen ,
Yes to apply the patch you will need to recompile the image.
Florent
HI @liufengwuhen ,
Do you have any updates on this? Were you able to test with the patch?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
