Visitor gourav_123
TMDS dos'nt connected to HDMI port
hello ,
I m trying to process Video stream through Zybo board,follows Digilent Zybo video workshop Pdf file In step by step methods.
But during connected TMDS Port to HDMI_in,it dosent connect using ctrl+t or not by Manual external port. I have attach that image below .Even though after click on board property on Dvi2rgb ip that Hdmi port not shows any connection.If i connect TMDS internal port as their respective external it shows error.
Pls provide some solution
Tags (2)
Re: TMDS dos'nt connected to HDMI port
Hi @gourav_123,
I believe this question might be better on the Digilent forums.
On thing you might want to mahe sure is to use the same version of vivado as in the tutorial.
Florent
