TPG license not found
I am using VIVADO 2018.2 version. I want to use Test pattern generator IP for my design but it is showing license not found. For this IP there is no evaluation license available but in IP catalog , license status shows "included". What does it mean. I tried this link https://www.xilinx.com/support/answers/66350.html as well but no TPG license is available in Xilinx license solution  center.
Re: TPG license not found
Hi @nidhipanda15,
You might want to use 2018.3, as there is no need for a license for the TPG from this version.
If you still want to use 2018.2, use the following steps:
  1. Go to your Xilinx Licensing account
  2. Click on Search Now in the Evaluation and No Charges Cores
  3. Search for the Test Pattern Generator
  4. Then generate the license as any other license.
Hope that helps,
Hi @nidhipanda15,
Hope that helps,
