Visitor xjtusirius
Ultra high-speed CMOS image sensor signal processing
I am designing a CMOS image sensor system with Artix-7 (XC7A200-2) FPGA, the CMOS sensor outputs video stream through 16 LVDS channels, the frame rate is up to 1000 Frames/s @ 1280 x 1024. I know there are some image processing IP provide by Artix-7/ Vivado. My question is whether those IPs can support such high speed frame rate/data rate? Do you have any reference doc/design except  xapp794?
Scholar watari
Re: Ultra high-speed CMOS image sensor signal processing
Hi @xjtusirius
The important point is how to receive this signal from CMOS sensor.
How do you receive it ?
BTW, I guess the following url (post) is helpful for you.
Your question is similer the followings.
Would you read it ?
https://forums.xilinx.com/t5/Video/LVDS-camera-interface-deserialization-question/td-p/908551
Best regards,
Scholar watari
Hi @xjtusirius
Would you read it ?
Best regards,
Visitor xjtusirius
Hi @watari,
Thanks for reply, the vender of CMOS sensor provides the IP solution to receive 16 channel (12b/pixel, RGB format) LVDS data, then combines to a 192bit data @ 45MHz. Can I directly use the video processing IP to process the data?
Scholar watari
Hi @xjtusirius
Unfortunately, you should design an original receiver logic.
However, you can refer the similar solution, as I already mentioned previous post (link)m and consider it.
Best regards,
Hi @xjtusirius,
Is everything clear for you on this subject?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
