Newbie jf.pascolo
Ultrascale+ / simultaneous h264 and h265 encoding
I found that Ultrascale+ EV supports 8 simultaneous encoding in h264 or h265.
But does it support encoding in h264 AND h265 at same time ?
And if yes, does it support "8 h264 encoding + 8 h265 encoding" or (it makes more sense) a global "8 h264/h265 encoding" ?
Thanks for any answer.
Re: Ultrascale+ / simultaneous h264 and h265 encoding
HI @jf.pascolo,
Yes it is possible for the ZU+ MPSoC VCU to have different streams using different standards. This is controlled through the software APIs.
So yes you can do 8 h264/h265 encoding (1 h264 + 7 h265 OR 2 h264 + 6 h265 OR ... OR 4 h264 + 4 h265 + ... OR 8 h264 OR 8 h265).
HI @jf.pascolo,
Newbie jf.pascolo
Hi @florentw,
This is a really good thing for me, great !
Thanks a lot for yous answer.
Jean-François
Visitor yyq1994
Hello! I want to know if can I use Ultrascale+ EV to encode one video to three different resolution h265 streams simultaneously? For example, the video input is 4K, I want to get 4K@60fps, 1080P@30fps and 640x480@30fps simultaneously. Can I realize this with Xilinx MPSoc? It will helps me a lot.
HI @yyq1994,
This is a different question, please create a new topic on the Video Board  (click on "New message")
