VCAP initialization failed on petalinux
hello,
i am creating a project including a test pattern generator and a frame buffer writer. i did the reauired modification for the device tree. you can check the attached files. Im using CZU11EG. i need to write to DDR a patern from VIDEO TPG then to display the pattern through the DipslayPort on PS part.
when i load petalinux, i get a failure for the VCAP_tpg node to video capture.
i tried to add the capture in amba as well as oin amba_pl and for both it is not working , still getting the same problem
could you please propose a solution ?
thanks
Re: VCAP initialization failed on petalinux
Hi @mohamadoussayran1 ,
What petalinux version are you using?
If might be helpfull to share the full log as well.
Florent
hello @florentw ,
i created a thread https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-build-errors/m-p/956661#M32621 which describes my problem more in details.
thank you,
regards
mohamad
HI @mohamadoussayran1 ,
I would like to focus on the error you have on the master branch with the vcap error. Can you provide the log for linux?
Florent
