VCU - Encoded Video to PL
I am using petalinux and gstreamer pipelines to encode video and encapsulate it with MPEG2TS and send it through Ethernet.
Now I need to send the MPEG2 Transport Stream to PL. How can this be achieved?
Best Regards.
Mustafa
Re: VCU - Encoded Video to PL
Hi @mcetinsoy
The result of the VCU is stored in the memory. So you just need to use a DMA to do memory to PL.
Note that the VDMA will not work as it is expecting encoded format. But you might use another one.
OK, I am looking into using AXI DMA for the job.
1-) I assume I can just add an AXI DMA IP connected to one of the HP ports of the ps.
2-) For the gstreamer pipeline what would be my sink? Can I just use fakesink?
3-) What would be the starting address for the encoded stream on the PS DDR?
Best Regards.
Mustafa
Scholar watari
Hi @mcetinsoy
What protocol do you want to use ?
It depends on your protocol (TCP, UDP, RTP, RTSP and so on) in your sink.
Hi @mcetinsoy,
Is everything clear ofr you on this topic?
If this is not solved/answered, please reply to the topic giving more information on your current status.
Thanks and Regards,
Xilinx Video Design Hub
I still can't get my head around this, so any help is appreciated.
So I will be using DMA for PS DDR to PL;
  • How can I find or manage the address range for VCU output?
  • Should I use mmap for DMA IP to control and initiate the transfers?
Thank you.
Mustafa
@mcetinsoyIt sounds like your goad is to use the VCU encoder to encode the Video and then to package it up as MPEG-TS and send send the MPEG-TS to your PL logic.  Also, the plan is to use GStreamer, to do the packetization of the output video in an MPEG-TS  It is unclear why you want to round the MPEG-TS to the PL, but here are a couple of things that you might want to look at.
  1. GStreamer offers an IP called appsink which can be used to DMA data in a custom IP that might sit into the PL.  There is an example on the Xilinx Wiki that may be of some help.
    Video Data Modification in Gstreamer Application
  2. Also you might want to take a look at the demo that shows how to capture 10G data and then decode it and send it to HDMI Tx.  This is the opposite of what you are trying to do, but it may still be useful to just look at to get some ideas on how to interface PL with GStreamer.
    Zynq UltraScale+ MPSoC VCU TRD 2019.1 - 10G HDMI Video Capture and HDMI Display
Chris
Video Design Hub | Embedded SW Support
Thank you @chrisar .
The reason I am trying to send the MPEG-TS to PL is I have custom cryptographic function residing there.
I will look into this further with your guidance.
Best Regards.
Mustafa
Hi @mcetinsoy
Do you have any update on this?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
