Observer gefei-liuqi
VCU encode 4:2:2 10bit
I have a YUV file which format is 4:2:2 10bit. Then I use VCU to encode it, as
gst-launch-1.0 filesrc location="input.yuv"  !  videoparse  format=nv16-10le32 width=3840 height=2160 framerate=25/1  !  omxh264enc  ! filesink location ="output.h264"
The file output.h264  cannot be decoded rightly!
I used zcu106 with TRD-2018.3
Re: VCU encode 4:2:2 10bit
Hi @gefei-liuqi,
Unfortunately, the VCU TRD 2018.3 does not support 10 bit data (i.e. NV16 is not supported). It should be supported in a future release.
ok! Thanks for your response!
But when I use the command like this
  gst-launch-1.0 filesrc location=/mnt/input.h264 ! h264parse ! omxh264dec ! queue max-size-bytes=0 ! omxh264enc num-slices=8 control-rate=2 b-frames=0 gop-length=1 target-bitrate=400000 ! filesink location=/mnt/output.h264
the Encoded file output.h264 can be played well with the VLC player!
  the input.h264 is 4:2:2 10bit, while the output.h264 is 4:2:2 10bit too!
I do not know why
HI @gefei-liuqi,
Can you try with the ZCU106 BSP (link) instead of the VCU TRD?
I have tested  2018.3-zcu106-release.
It can not work too.
so, I wonder to know whether the VCU support NV16-10le32 encoder or  NV16 encoder?
HI @gefei-liuqi,
According to PG252, the VCU can do both:
 Are you sure your YUV file is correct?
The raw yuv file is stored by this command:
ctrlsw_decode  -i  4k_input.h264  -out output.yuv  -avc  --prealloc-args 3840x2160:progr:422:10:11:52
while the 4k_input.h264 is 4:2:2 10bit format,  and the YUV file can be showed rightly with pYUV tool.
