Visitor ippfcox
VCU encode failed for pitch align
I'm using zcu106, on pg252-vcu page 148, AL_Encoder_Process(), it says "The Chroma pitch must be 32-bit aligned", when I pass NV12 720x480P YUV(720 bytes per line and new line followed ) to encoder, encoded frame is not correct, I tried to align a line to 736 bytes(this means 32 bytes aligned instead of 32 bit aligened) with filling zero bytes (using cpu memcpy), encoded frame will be correct.
When I tried to set v4l2_format's bytesperline to 736 bytes, but it doesn't work, the captured YUV is not aligned to 736 bytes.
Briefly, how can I capture 720x480P NV12 and encode it without cpu memcpy?
Is there any parameters that I didn't set correctly?
Visitor ippfcox
回复: VCU encode failed for pitch align
I don't know if there is anybody have the same problem with me, post the solution here.
For the reason that V4L2_BUF_TYPE_VIDEO_CAPTURE_MPLANE is used to capture video, the parametersto be set should be
v4l2_fmt.fmt.pix_mp.plane_fmt[0].bytesperline
instead of
v4l2_fmt.fmt.pix.bytesperline
then the captured data will be 32 bytes aligned on every line.
Visitor ippfcox
instead of
Hi @ippfcox ,
Thank you for sharing your solution. Could you kindly mark it as accepetd solution to make sure other members having the same issue find their answer quickly?
Florent
