Participant hitpmpm@163.com
VDMA write channel config failed
hello everyone
I am doing the motion detection project on zedboard .   firstly, I want to capture the video by the ov5640 ,then pass it to hdmi to display, but when I use the vdma to transfer data from ddr to pl ,it met problem in SDK as follows thanks!
 my block design is as follows
besides,my  code is as follow
main.c
#include "sys_intr.h"
#include "xaxivdma.h"
#include "xaxivdma_i.h"
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
//#define VTC_BASEADDR XPAR_MIZ702_VTG_VGA_0_BASEADDR
#define DDR_BASEADDR        0x00100000
#define UART_BASEADDR       0xe0001000
#define VDMA_BASEADDR       XPAR_AXI_VDMA_0_BASEADDR
#define H_STRIDE            1280
#define H_ACTIVE            1280
#define V_ACTIVE            720
#define pi					3.14159265358
#define COUNTS_PER_SECOND	(XPAR_CPU_CORTEXA9_CORE_CLOCK_FREQ_HZ)/64
#define VIDEO_LENGTH  (H_STRIDE*V_ACTIVE)
#define VIDEO_BASEADDR0 DDR_BASEADDR + 0x2000000
#define VIDEO_BASEADDR1 DDR_BASEADDR + 0x3000000
#define VIDEO_BASEADDR2 DDR_BASEADDR + 0x4000000
u32 *BufferPtr[3];
unsigned int srcBuffer = 0x00000000;//(XPAR_PS7_DDR_0_S_AXI_BASEADDR  + 0x1000000);
int run_triple_frame_buffer(XAxiVdma* InstancePtr, int DeviceId, int hsize,
		int vsize, int buf_base_addr, int number_frame_count,
		int enable_frm_cnt_intr);
int main(void)
	init_platform();
	u32 Status;
	Miz702_EMIO_init();
	ov5640_init_rgb();
	XAxiVdma InstancePtr;
	xil_printf("Starting the first VDMA \n\r");
	Status = run_triple_frame_buffer(&InstancePtr, 0, 1280, 720,
							srcBuffer, 2, 0);
		if (Status != XST_SUCCESS) {
			xil_printf("Transfer of frames failed with error = %d\r\n",Status);
			return XST_FAILURE;
		} else {
			xil_printf("Transfer of frames started \r\n");
	print("TEST PASS\r\n");
	//VDMA configurateAXI VDMA0
	/*****************往DDR写数据设置**********************/
	/*Xil_Out32((VDMA_BASEADDR + 0x030), 0x00000003);// enable circular mode
	Xil_Out32((VDMA_BASEADDR + 0x0AC), VIDEO_BASEADDR0);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x0B0), VIDEO_BASEADDR1);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x0B4), VIDEO_BASEADDR2);	// start address
	Xil_Out32((VDMA_BASEADDR + 0x0A8), (H_STRIDE*4));		// h offset (640 * 4) bytes
	Xil_Out32((VDMA_BASEADDR + 0x0A4), (H_ACTIVE*4));		// h size (640 * 4) bytes
	Xil_Out32((VDMA_BASEADDR + 0x0A0), V_ACTIVE);			// v size (480)
	/*****************从DDR读数据设置**********************/
	/*Xil_Out32((VDMA_BASEADDR + 0x000), 0x00000003); 		// enable circular mode
	Xil_Out32((VDMA_BASEADDR + 0x05c), VIDEO_BASEADDR0); 	// start address
	Xil_Out32((VDMA_BASEADDR + 0x060), VIDEO_BASEADDR1); 	// start address
	Xil_Out32((VDMA_BASEADDR + 0x064), VIDEO_BASEADDR2); 	// start address
	Xil_Out32((VDMA_BASEADDR + 0x058), (H_STRIDE*4)); 		// h offset (640 * 4) bytes
	Xil_Out32((VDMA_BASEADDR + 0x054), (H_ACTIVE*4)); 		// h size (640 * 4) bytes
	Xil_Out32((VDMA_BASEADDR + 0x050), V_ACTIVE); 			// v size (480)
	while (1) ;
		return XST_SUCCESS;
	   // cleanup_platform();
	    //return 0;
vdma_api.c
#define DEBUG_MODE		0
/******************** Include files **********************************/
#include "xparameters.h"
#include "xil_exception.h"
/******************** Data structure Declarations *****************************/
typedef struct vdma_handle
	/* The device ID of the VDMA */
	unsigned int device_id;
	/* The state variable to keep track if the initialization is done*/
	unsigned int init_done;
	/** The XAxiVdma driver instance data. */
	XAxiVdma* InstancePtr;
	/* The XAxiVdma_DmaSetup structure contains all the necessary information to
	 * start a frame write or read. */
	XAxiVdma_DmaSetup ReadCfg;
	XAxiVdma_DmaSetup WriteCfg;
	/* Horizontal size of frame */
	unsigned int hsize;
	/* Vertical size of frame */
	unsigned int vsize;
	/* Buffer address from where read and write will be done by VDMA */
	unsigned int buffer_address;
	/* Flag to tell VDMA to interrupt on frame completion*/
	unsigned int enable_frm_cnt_intr;
	/* The counter to tell VDMA on how many frames the interrupt should happen*/
	unsigned int number_of_frame_count;
}vdma_handle;
/******************** Constant Definitions **********************************/
 * Device related constants. These need to defined as per the HW system.
vdma_handle vdma_context[XPAR_XAXIVDMA_NUM_INSTANCES];
static unsigned int context_init=0;
/******************* Function Prototypes ************************************/
static int ReadSetup(vdma_handle *vdma_context);
static int WriteSetup(vdma_handle *vdma_context);
static int StartTransfer(XAxiVdma *InstancePtr);
* run_triple_frame_buffer API
* This API is the interface between application and other API. When application will call
* this API with right argument, This API will call rest of the API to configure the read
* and write path of VDMA,based on ID. After that it will start both the read and write path
* of VDMA
* @param	InstancePtr is the handle to XAxiVdma data structure.
* @param	DeviceId is the device ID of current VDMA
* @param	hsize is the horizontal size of the frame. It will be in Pixels.
* 		The actual size of frame will be calculated by multiplying this
* 		with tdata width.
* @param 	vsize is the Vertical size of the frame.
* @param	buf_base_addr is the buffer address where frames will be written
*		and read by VDMA.
* @param 	number_frame_count specifies after how many frames the interrupt
*		should come.
* @param 	enable_frm_cnt_intr is for enabling frame count interrupt
*		when set to 1.
* @return
*		- XST_SUCCESS if example finishes successfully
*		- XST_FAILURE if example fails.
	int Status,i;
	XAxiVdma_Config *Config;
	XAxiVdma_FrameCounter FrameCfgPtr;
	/* This is one time initialization of state machine context.
	 * In first call it will be done for all VDMA instances in the system.
	if(context_init==0) {
		for(i=0; i < XPAR_XAXIVDMA_NUM_INSTANCES; i++) {
			vdma_context[i].InstancePtr = NULL;
			vdma_context[i].device_id = -1;
			vdma_context[i].hsize = 0;
			vdma_context[i].vsize = 0;
			vdma_context[i].init_done = 0;
			vdma_context[i].buffer_address = 0;
			vdma_context[i].enable_frm_cnt_intr = 0;
			vdma_context[i].number_of_frame_count = 0;
		context_init = 1;
	/* The below initialization will happen for each VDMA. The API argument
	 * will be stored in internal data structure
	/* The information of the XAxiVdma_Config comes from hardware build.
	 * The user IP should pass this information to the AXI DMA core.
	Config = XAxiVdma_LookupConfig(DeviceId);
	if (!Config) {
		xil_printf("No video DMA found for ID %d\r\n",DeviceId );
		return XST_FAILURE;
	if(vdma_context[DeviceId].init_done ==0) {
		vdma_context[DeviceId].InstancePtr = InstancePtr;
		/* Initialize DMA engine */
		Status = XAxiVdma_CfgInitialize(vdma_context[DeviceId].InstancePtr,
						Config, Config->BaseAddress);
			xil_printf("Configuration Initialization failed %d\r\n",
					Status);
			return XST_FAILURE;
		vdma_context[DeviceId].init_done = 1;
	vdma_context[DeviceId].device_id = DeviceId;
	vdma_context[DeviceId].vsize = vsize;
	vdma_context[DeviceId].buffer_address = buf_base_addr;
	vdma_context[DeviceId].enable_frm_cnt_intr = enable_frm_cnt_intr;
	vdma_context[DeviceId].number_of_frame_count = number_frame_count;
	vdma_context[DeviceId].hsize = hsize * (Config->Mm2SStreamWidth>>3);
	/* Setup the write channel */
	Status = WriteSetup(&vdma_context[DeviceId]);
		xil_printf("Write channel setup failed %d\r\n", Status);
		if(Status == XST_VDMA_MISMATCH_ERROR)
			xil_printf("DMA Mismatch Error\r\n");
		return XST_FAILURE;
	else
		xil_printf("Write channel setup sucess %d\r\n", Status);
	/* Setup the read channel */
	Status = ReadSetup(&vdma_context[DeviceId]);
		xil_printf("Read channel setup failed %d\r\n", Status);
		return XST_FAILURE;
	/* The frame counter interrupt is enabled, setting VDMA for same */
	if(vdma_context[DeviceId].enable_frm_cnt_intr) {
		FrameCfgPtr.ReadDelayTimerCount = 1;
		FrameCfgPtr.ReadFrameCount = number_frame_count;
		FrameCfgPtr.WriteDelayTimerCount = 1;
		FrameCfgPtr.WriteFrameCount = number_frame_count;
		XAxiVdma_SetFrameCounter(vdma_context[DeviceId].InstancePtr,&FrameCfgPtr);
		/* Enable DMA read and write channel interrupts. The configuration for interrupt
		 * controller will be done by application	 */
		XAxiVdma_IntrEnable(vdma_context[DeviceId].InstancePtr,
				XAXIVDMA_IXR_ERROR_MASK |
				XAXIVDMA_IXR_FRMCNT_MASK,XAXIVDMA_WRITE);
				XAXIVDMA_IXR_FRMCNT_MASK,XAXIVDMA_READ);
	} else	{
					XAXIVDMA_IXR_ERROR_MASK,XAXIVDMA_WRITE);
					XAXIVDMA_IXR_ERROR_MASK ,XAXIVDMA_READ);
	/* Start the DMA engine to transfer */
	Status = StartTransfer(vdma_context[DeviceId].InstancePtr);
		return XST_FAILURE;
#if DEBUG_MODE
	xil_printf("Code is in Debug mode, Make sure that buffer addresses are at valid memory \r\n");
	xil_printf("In triple mode, there has to be six consecutive buffers for Debug mode \r\n");
		u32 pixels,j,Addr = vdma_context[DeviceId].buffer_address;
		u8 *dst,*src;
		u32 total_pixel = vdma_context[DeviceId].WriteCfg.Stride * vdma_context[DeviceId].vsize;
		src=(unsigned char *)Addr;
		dst = (unsigned char *)Addr + (total_pixel * vdma_context->InstancePtr->MaxNumFrames);
		for(j=0;j<vdma_context->InstancePtr->MaxNumFrames;j++) {
			for(pixels=0;pixels<total_pixel;pixels++) {
				if(src[pixels] != dst[pixels]) {
					xil_printf("VDMA transfer failed: src=0x%x, DST=0x%x\r\n",
							src[pixels],dst[pixels]);
					exit(-1);
			src=src + total_pixel;
			dst = dst + total_pixel;
	xil_printf("VDMA transfer is happening and checked for 3 frames \r\n");
#endif
	return XST_SUCCESS;
* This function sets up the read channel
* @param	vdma_context is the context pointer to the VDMA engine.
* @return	XST_SUCCESS if the setup is successful, XST_FAILURE otherwise.
* @note		None.
	int Index;
	u32 Addr;
	int Status;
	vdma_context->ReadCfg.VertSizeInput = vdma_context->vsize;
	vdma_context->ReadCfg.HoriSizeInput = vdma_context->hsize;
	vdma_context->ReadCfg.Stride = vdma_context->hsize;
	vdma_context->ReadCfg.FrameDelay = 1;  /* This example does not test frame delay */
	vdma_context->ReadCfg.EnableCircularBuf = 1;
	vdma_context->ReadCfg.EnableSync = 1;  /* Gen-Lock */
	vdma_context->ReadCfg.PointNum = 0;
	vdma_context->ReadCfg.EnableFrameCounter = 0; /* Endless transfers */
	vdma_context->ReadCfg.FixedFrameStoreAddr = 0; /* We are not doing parking */
	/* Configure the VDMA is per fixed configuration, This configuration is being used by majority
	 * of customer. Expert users can play around with this if they have different configurations */
	Status = XAxiVdma_DmaConfig(vdma_context->InstancePtr, XAXIVDMA_READ, &vdma_context->ReadCfg);
		xil_printf("Read channel config failed %d\r\n", Status);
		return XST_FAILURE;
	/* Initialize buffer addresses
	 * These addresses are physical addresses
	Addr = vdma_context->buffer_address;
	for(Index = 0; Index < vdma_context->InstancePtr->MaxNumFrames; Index++) {
		vdma_context->ReadCfg.FrameStoreStartAddr[Index] = Addr;
		/* Initializing the buffer in case of Debug mode */
#if DEBUG_MODE
			u32 i;
			u8 *src;
			u32 total_pixel = vdma_context->ReadCfg.Stride * vdma_context->vsize;
			xil_printf("Read Buffer %d address: 0x%x \r\n",Index,Addr);
			for(i=0;i<total_pixel;i++)
				src[i] = i & 0xFF;
#endif
		Addr +=  vdma_context->hsize * vdma_context->vsize;
	/* Set the buffer addresses for transfer in the DMA engine
	 * The buffer addresses are physical addresses
	Status = XAxiVdma_DmaSetBufferAddr(vdma_context->InstancePtr, XAXIVDMA_READ,
			vdma_context->ReadCfg.FrameStoreStartAddr);
		xil_printf(
			"Read channel set buffer address failed %d\r\n", Status);
		return XST_FAILURE;
	return XST_SUCCESS;
* This function sets up the write channel
* @param	dma_context is the context pointer to the VDMA engine..
* @note		None.
	int Index;
	u32 Addr;
	int Status;
	vdma_context->WriteCfg.VertSizeInput = vdma_context->vsize;
	vdma_context->WriteCfg.HoriSizeInput = vdma_context->hsize;
	vdma_context->WriteCfg.Stride = vdma_context->hsize;
	vdma_context->WriteCfg.FrameDelay = 0;  /* This example does not test frame delay */
	vdma_context->WriteCfg.EnableCircularBuf = 1;
	vdma_context->WriteCfg.EnableSync = 1;  /*  Gen-Lock */
	vdma_context->WriteCfg.PointNum = 0;
	vdma_context->WriteCfg.EnableFrameCounter = 0; /* Endless transfers */
	vdma_context->WriteCfg.FixedFrameStoreAddr = 0; /* We are not doing parking */
	 * is being used by majority of customers. Expert users can play around
	 * with this if they have different configurations
	Status = XAxiVdma_DmaConfig(vdma_context->InstancePtr, XAXIVDMA_WRITE, &vdma_context->WriteCfg);
		xil_printf(
			"Write channel config failed %d\r\n", Status);
		return Status;
	 * Use physical addresses
	/* If Debug mode is enabled write frame is shifted 3 Frames
	 * store ahead to compare read and write frames
#if DEBUG_MODE
	Addr = Addr + vdma_context->InstancePtr->MaxNumFrames * \
			(vdma_context->WriteCfg.Stride * vdma_context->vsize);
#endif
		vdma_context->WriteCfg.FrameStoreStartAddr[Index] = Addr;
#if DEBUG_MODE
		xil_printf("Write Buffer %d address: 0x%x \r\n",Index,Addr);
#endif
		Addr += (vdma_context->hsize * vdma_context->vsize);
	/* Set the buffer addresses for transfer in the DMA engine */
			XAXIVDMA_WRITE,
			vdma_context->WriteCfg.FrameStoreStartAddr);
		xil_printf("Write channel set buffer address failed %d\r\n",
				Status);
		return XST_FAILURE;
	/* Clear data buffer
#if DEBUG_MODE
	memset((void *)vdma_context->buffer_address, 0,
			vdma_context->ReadCfg.Stride * vdma_context->ReadCfg.VertSizeInput * vdma_context->InstancePtr->MaxNumFrames);
#endif
	return XST_SUCCESS;
* This function starts the DMA transfers. Since the DMA engine is operating
* in circular buffer mode, video frames will be transferred continuously.
* @param	InstancePtr points to the DMA engine instance
* @return
*		- XST_SUCCESS if both read and write start successfully
*		- XST_FAILURE if one or both directions cannot be started
* @note		None.
	int Status;
	/* Start the write channel of VDMA */
	Status = XAxiVdma_DmaStart(InstancePtr, XAXIVDMA_WRITE);
		xil_printf("Start Write transfer failed %d\r\n", Status);
		return XST_FAILURE;
	/* Start the Read channel of VDMA */
	Status = XAxiVdma_DmaStart(InstancePtr, XAXIVDMA_READ);
		xil_printf("Start read transfer failed %d\r\n", Status);
		return XST_FAILURE;
	return XST_SUCCESS;
Re: VDMA write channel config failed
As i see in your code sometimes you use 1280*720 and sometimes you have settings for 640*480.
Could you set one resolution not both or this is a part of your design with different resolutions?
Sorry for my English.
HI hitpmpm@163.com,
Do you still have issue on this?
Dir the reply from @mkorobkov helped you? If yes could you mark it as accepted solution (button accept as solution below the reply when logged in) to close the topic?
Thanks and regards,
Visitor nomi_070
Hello hitpmpm@163.com
Did you solve your problem. I am having the same problem could you please guide me how you solved it.
HI @nomi_070 ,
Please create a new topic if you have an issue, you have more chance of getting helped
Also you might want to have a look at my Video Series 24: Using the AXI VDMA in Triple Buffer Mode and Video Series 25: Debugging issues on the AXI VDMA IP
