[Video Beginner Series 4] Updated TPG to use 4PPC getting 'Z' in pixels 1,2,3
@florentw Thanks so much for your video beginner series, these are extremely useful!
I have ran your simulation successfully and it passed.   In order to use your setup to debug a block I will be developing I need to use 4 pixels per clock in the design since that is what my final design will use, so I updated the block design to have the TPG use 4PPC (see image 1 below).   I also updated the BD connection to have a [95:0] connection and updated the tpg_tdata in the testbench to be [95:0] and this all synthesized and the simulation runs.   But I notice pixel 0 in TDATA is there and changing as expected, but pixels 1,2,3 are all 'Z' (see image 2 below).   Do you know if the TPG supports simulating 4PPC, or is this not an option?
Oh, one other change I made is I changed the lines below to match the resolution I am using in my actual hardware design:
// VIP Configuration
integer height=2160, width=3840;
Image 1:
Image 2:
Tim
Re: [Video Beginner Series 4] Updated TPG to use 4PPC getting 'Z' in pixels 1,2,3
Never mind, resetting output products in the 2018.1 design was needed.   Once I did that and regenerated output products (having to also disable cache and clear the cache), then the design is now outputting 4PPC.
Tim
As an experiment I replicated the design in 2017.4 and it seems to work there (see image below).   I notice that the TPG is Version 7.0 (Rev. 10) in 2018.1 and 7.0 (Rev. 9) in 2017.4.   Maybe TPG 7.0 (Rev 10) will not simulate 4PPC?
Tim
Tim
Hi @tim_severance,
Good to know that you are successfully using my Video Series and good to know that you solved your issue.
@florentw, question.   In the simulation the axi-stream video tdata bus is changing value on the rising edge of t_clk.   Is this how it works in actual implementation as well?   If so I will need to setup my RTL which looks at this data to capture the data on the negedge of the clock.
Tim
Hi @tim_severance,
Yes you usually change the value on the rising edge of the clock. And the clock should propagate with the data so you should need to capture it on the rising edge.
You can run post-implementation timing simulation if you want to take propagation in account
