[Video Beginner Series 6] How to conect the Video Out to VGA
My question is very straightforward: i'm trying to connect the Video Out output of the project of this chapter to the VGA Output in a way that I can view the video pattern in my monitor. How can I do it?
I though I just needed to add some constraint. I tryied something, but it didn't gone right, I think i'm connecting them the wrong way. My constraints file is attached to this topic. When I try to generate the bitstream with it, I get the following error:
Tags (2)
Re: [Video Beginner Series 6] How to conect the Video Out to VGA
HI @tiago0297,
You literally have to write one line of code just to have the data = 0 during blanking period
Florent
Well, for some reason I can't attach my constraints file. Here goes it's content:
set_property PACKAGE_PIN Y9 [get_ports clk_in]
set_property PACKAGE_PIN AA19 [get_ports vid_hsync]
set_property PACKAGE_PIN Y19 [get_ports vid_vsync]
set_property PACKAGE_PIN AA21 [get_ports {vid_data[19]}]
set_property PACKAGE_PIN AB21 [get_ports {vid_data[18]}]
set_property PACKAGE_PIN AA22 [get_ports {vid_data[17]}]
set_property PACKAGE_PIN AB22 [get_ports {vid_data[16]}]
set_property PACKAGE_PIN AB19 [get_ports {vid_data[11]}]
set_property PACKAGE_PIN AB20 [get_ports {vid_data[10]}]
set_property PACKAGE_PIN Y20 [get_ports {vid_data[9]}]
set_property PACKAGE_PIN Y21 [get_ports {vid_data[8]}]
set_property PACKAGE_PIN V18 [get_ports {vid_data[3]}]
set_property PACKAGE_PIN V19 [get_ports {vid_data[2]}]
set_property PACKAGE_PIN U20 [get_ports {vid_data[1]}]
set_property PACKAGE_PIN V20 [get_ports {vid_data[0]}]
set_property IOSTANDARD LVCMOS33 [get_ports -of_objects [get_iobanks 33]];
set_property IOSTANDARD LVCMOS33 [get_ports -of_objects [get_iobanks 13]];
Scholar watari
Hi @tiago0297
How do you connect to your monitor ? Analog RGB (VGA) ? DVI ? HDMI ? DisplayPort ? or other ?
Also what kind of board do you use ?
Best regards,
Hi, @watari
I use a VGA and a ZedBoard
HI @tiago0297,
Tip: The Video Beginner Series 1: Introduction to Digital Video might be a good start for this ;)
Florent
Hi, @florentw
I actually used the first chapter to try to modify the sixth. What I did was to use the same constraint file, but renaming the red, blue and green signals to the vid_data[0...3] (red), vid_data[8...11] (blue) and vid_data[16...19] (green). But some bis and signals remain missing and I'm getting this error. I'm trying to figure out what I did wrong, but I'm not being so successfull at it :/
Hi @tiago0297,
TIP2: Check your error message. What ports is this message talking about? Did you create any specific constraint to these ports? (ex. vid_data[4])
TIP3: Each port on the top level wrapper which is an input/output needs to be assigned to a pin
Florent
Hi @florentw, thanks for the tips, but I still didn't get it.
I took a look in the ZedBoard datasheet and verified that works with 12 bit color. That explains to me why in the first project half of each channel, red, green and blue are not assigned to any pin. I think my main question is how I organize this vid_data bits, since they are 24, and the other signals if there is no pinout for them. Why in the first project Vivado gave no error on some bits unconnected?
HI @tiago0297,
In the Video Series 1, all the input/ouptuts from the vivado design are assigned to a pin of the device.
You need to modify the wrapper to unconnect the port from the top level module or create a new wrapper on top of the wrapper
Florent
Hi, @florentw
I tryied to modify my wrapper using the first tutorial as reference. Now, the bitstream was succesfully generated, but no image from the TPG was shown in my screen. I think I've done something wrong on my wrapper or my constraints. Never modified the wrapper before, so I don't know if I did something wrong. Can you take a look at what i've done?
My new constraints file:
set_property PACKAGE_PIN Y9 [get_ports aclk_40MHz]
set_property PACKAGE_PIN AA21 [get_ports {vid_data[11]}]
set_property PACKAGE_PIN AB21 [get_ports {vid_data[10]}]
set_property PACKAGE_PIN AA22 [get_ports {vid_data[9]}]
set_property PACKAGE_PIN AB22 [get_ports {vid_data[8]}]
set_property PACKAGE_PIN AB19 [get_ports {vid_data[7]}]
set_property PACKAGE_PIN AB20 [get_ports {vid_data[6]}]
set_property PACKAGE_PIN Y20 [get_ports {vid_data[5]}]
set_property PACKAGE_PIN Y21 [get_ports {vid_data[4]}]
My wrapper:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library UNISIM;
use UNISIM.VCOMPONENTS.ALL;
entity AXI4S_to_Vid_Out_bd_wrapper is
port (
aclk_40MHz : in STD_LOGIC;
aresetn_0 : in STD_LOGIC;
vid_data : out STD_LOGIC_VECTOR ( 11 downto 0 );
vid_hsync : out STD_LOGIC;
vid_vsync : out STD_LOGIC
end AXI4S_to_Vid_Out_bd_wrapper;
architecture STRUCTURE of AXI4S_to_Vid_Out_bd_wrapper is
signal data : std_logic_vector(23 downto 0);
component AXI4S_to_Vid_Out_bd is
port (
vid_active_video : out STD_LOGIC;
vid_data : out STD_LOGIC_VECTOR ( 23 downto 0 );
vid_hblank : out STD_LOGIC;
vid_vblank : out STD_LOGIC;
end component AXI4S_to_Vid_Out_bd;
begin
AXI4S_to_Vid_Out_bd_i: component AXI4S_to_Vid_Out_bd
port map (
aclk_40MHz => aclk_40MHz,
vid_data(23 downto 0) => data(23 downto 0),
vid_hsync => vid_hsync,
vid_vsync => vid_vsync
vid_data <= data(11 downto 0);
end STRUCTURE;
HI @tiago0297,
Good to know that the bitstream is now generating.
To be fair, I was kind of expecting that you would get no output ;).
I think I know the root cause but I want you to find it by yourself. Run a simulation and check the (data) output signals of both design. You should see a subtle difference ;)
Florent
Hi, @florentw
I just runned both simulations, but I didn't found the difference.
Both the data signals looks the same for me. In the project 1, if you look at RGB data together, it makes a sequence of ffff00, ff00ff, 0000ff, or something like it. The same happens in project 6 when I look at the vid_data signal, sequences very much like that.
Can you explain to me?
Hi @tiago0297,
Did you check the value of the data between 2 frames or 2 lines?
Florent
Hi @florentw
When vsync_out raises, the values in the data differs between projects 1 and 6. In 1 they are all 000000, but in 6 they are 00ffffff. Is it what I'm supposed to observe? I didn't understood what's happening :/
Sorry for extending a lot this topic. I'm really in a hurry to complete this task for a university project, so I need a lot to make it work so I can proceed to the next steps.
Hi @tiago0297,
Yes this is what you are supposed to observe. So know you have an idea of what you need to do in 6
Florent
Hi, @florentw
I'm glad that i'm in the right direction. But I didn't understood why i'm getting this result and why it affects my output. What do I need to do to fix it?
Hi @tiago0297,
Well... You need to do some investigation and design by yourself...
You know what's failing. Why? It is just the VGA spec.
You need to find a solution. I will not do the design for you.
Florent
Thanks for the answer. Didn't expected you to do the design. Just a little more help from a instructor to a beginner ;) Don't know the use of knowing where the problem is if after a weekend researching I still have no clue on how to solve it.
HI @tiago0297,
Florent
Thanks. I'm glad it's a simple solution. I was thinking I needed to change something on the design itself, but didn't found out where. I guess it worked.
