Video Board - Knowledge Base and FAQ
Summary
1. Best Topics per Area/IP
2. Knowledge Base Per IP
3. Frequently Asked Questions per IP
  IPs/Areas ordered by the first letter:
LVDS Video Interface
Zynq-700 LVDS camera interface question
@watari and @klumsde give you the xapps to read to implement a video interface with LVDS
MPSoC DisplayPort Controller
Display-Port-to-HDMI-adapters
Interesting information on DP-to-HDMI adapters use on the MPSoC DisplayPort Controller by @watari
UHD-SDI IP
UHD-SDI Example design - ZCU102 Version
In this topic, @ajaykumargurrala shared the UHD-SDI example design (for ZCU106) moved to ZCU102.
 IPs ordered by the first letter:
 AXI Video Direct Memory Access (AXI VDMA)
 How to synchronize multiple VDMA MM2S cores?
See the answer from @reaiken -> link
HDCP (HDMI or DisplayPort)
How can I get a license to get HDCP enabled for the HDMI or DisplayPort Subsystems?
See the answer from @florentw -> link
HDMI Subsystems IP
Can I do HDMI without using the GTs?
See the answer from @chrisar -> link
Video Codec Unit (VCU)
How can I use PCIe with the VCU on Linux?
How can I feed data to the VCU?
Video Phy
What is the role of the video phy in my video system?
See the answer from @xud-> link
Can I use mixed protocol (DisplayPort + HDMI) with a single Video Phy?
See the answer from @xud -> link
3. Frequently Asked Questions per Area/IP
 Areas/IPs ordered by the first letter:
AXI Video Direct Memory Access (VDMA)
Where can I find a test bench for the VDMA?
The example design integrated in Vivado for the AXI VDMA contains a test bench you can use to simulate the AXI VDMA. Refer to PG020 - Chapter 5 for more information.
Florent
