Participant n.horvat
Video Processing Subsystem v1.0 licence
Hello!
I wanted to compile "xapp1285" in Vivado 2017.4 but then received this message:
ERROR: This script was generated using Vivado <2015.4> and is being run in <2017.4> of Vivado.
Please run the script in Vivado <2015.4> then open the design in Vivado <2017.4>. Upgrade the
design by running "Tools => Report => Report IP Status...", then run write_bd_tcl to create an updated script.
Then I installed Vivado 2015.4 and started "all.tcl" script again. In Vivado 2015.4 I received this error message:
Video Processing Subsystem (v1.0 (Rev. 1)) - IP License not found.
I have evaluation licence for Video Processing Subsystem (v2.0).
What should I do next to succesfully compile "xapp1285"? Thx!
Re: Video Processing Subsystem v1.0 licence
Hi @n.horvat,
1. Use 2015.4 (this is done)
2. Make sure you are correctly using the license. Could you share the output file from report_environment -file file.txt?
Thx,
Florent
Hi @n.horvat,
Thx,
Florent
