Visitor naeemahmad
Video data conversion from "Displayport video" to "Parallel video" on Artix 7bFPGA
Hi friends,
I am new to this community having basic knowledge of Vivado and Artix 7 FPGA.
In a Automotive project, i need parallel video data which should be consists of 12 bit video data, Hsync, Vsync and PCLK.
I want to get this parallel video output but my source is Displayport. So basically i need to convert Displayport data to parallel video data.
First i want to ask if it is possible with Artix 7 FPGA?
I read on following website IP "AX14-Stream to Video Out" that seems to be related my project.
https://www.xilinx.com/products/intellectual-property/axi4_stream_to_video_out.html
Please guide me.
Thank you
Kind regards
Naeem
Scholar u4223374
Re: Video data conversion from "Displayport video" to "Parallel video" on Artix 7bFPGA
Looks like you need the DisplayPort Subsystem. It's not free, but it'll do just what you need.
Scholar u4223374
HI @naeemahmad,
As @u4223374 said, you would just need the DisplayPort Subsystem. However the Xilinx IP is not supported on Artix-7.
You might want to discuss this with you FAE/sales contact.
Scholar watari
Hi @naeemahmad
What is your resolution and vertical frequency ?
Generally, Xilinx IP is not supported on Artix.
However, at least, if your resolution is under FHD (1920x1080@60Hz), I think it can work fine.
But, I suggest to ask it to your Xilinx FAE. Maybe helpful for you.
Hi @naeemahmad,
This topic is still open and is waiting for you:
    If your question is answered or your issue is solved, please mark the response which helped as solution
Best Regards,
