Visitor jinhanharu
Video frame looks orders were changed (NTSC with 2VDMA)
Hello guys,
I designed NTSC(RS170) video output (1280 X 480 resolution and 30Hz frame rates, pclk 24.54MHz with 2 VDMA
but the result is poor when I moved the camera, it sometimes(frequently) looks video frame orders are changed(video looks vibrated) but sometimes ok.
in my design,(VIVADO 16.3)
1. input image(1280 X 480, mono 16bit, 40MHz, 30Hz)
2. vid2axi4s : changed to axis
3. vdma1 : to change pclk from 40M to 49.08MHz
- frame buffer : 3
- write channel option : fsync(s2mm tuser), genlock(Dynamic Master), allow unaligned transfers checked
- read channel option : fsync(none), genlock(Dynamic Slave), allow unaligned transfers checked
4-1. vdma 2 : to output interlaced video, with 24.54MHz
- frame buffer : 4
- write channel option : fsync(s2mm tuser), genlock(Dynamic Slave)
- read channel option : fsync(none), genlock(Dynamic Master)
4-2. VTC : timing generator
5. axi4s2vidout : NTSC output
SDK VDMA REGISTER SET
FrameDelay = 0;
EnableCircularBuf = 1;
EnableSync = 1;
PointNum  = 0;
EnableFrameCounter = 0;
FixedFrameStoreAddr = 0;
I tried to resolve this issue like below but I couldn't get the good result
1. change set the both or one of vdma set(dynamic genlock to genlock)
2. change set the VDMA2 channel option
 - Read(Dynamic Slave), Write(Dynamic Master)
3. increasing frame buffer (VDMA1 : 3 to 6,  VDMA2 : 4 to 8)
4. all vdma allow unaligned transfers checked
5. all vdma allow unaligned transfers unchecked
Tags (2)
Re: Video frame looks orders were changed (NTSC with 2VDMA)
Hi @jinhanharu,
There is a simpler way to accomplish what you are trying to do. I believe that you only need 1 VDMA and not 2 which will simplify your design. The issue that you are seeing is possibly an issue with the first VDMA and the frame buffering with gunlock enabled.
Please see THIS thread which has an attached example on how to convert progressive video to interlaced video.
Sam
Xilinx Video Design Hub
Hi @jinhanharu,
My first thought is that something is wrong with how you are using genlock with the interlaced VDMA core, but I need some more information.
Can you provide a screenshot of your block design?
Can you provide a screenshot of the VDMA core that is doing the interlacing?
What are you setting the vsize, hsize, and stride register values to?
Also is there any backpressure in your system?  (ready signals going low)
Do any of your cores report any overflow?
Sam
Hi @jinhanharu,
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" buton below the reply)
Thanks and Regards,
Florent
Visitor jinhanharu
Sorry, I was off from my office so I could't check email and community.
I'll feed back what you want soon
Visitor jinhanharu
Hello, thanks and sorry, Samk
=> please check attachments below
=> for NTSC serration1,2 pulses(for distingushing even and odd frames) I put the sync generator I designed
=> image is ok , but freqeuntly image delayed when moved image ( I think it looks frame buffer number-time order is changed)
 VDMA1(main_axi_vdma_60Hz, the name 60 is my mistake , real frame rate is 30Hz)
- for changing the pixel clock 40M to 49.08MHz (30Hz)
- frame buffers : 3
- write channel option is s2mm tuser, dynamic master
- read channel option is none, dynamic slave
- allow unaligned transfers are checked
VDMA2(main_axi_vdma_60i, the name 60 is my mistake , real frame rate is 30Hz)
- for interlacing output
- frame buffers : 4
- write channel option is s2mm tuser, dynamic slave
- read channel option is none, dynamic master
- vsize:1280*2
- hsize : 480
- write stride : 1280*2
- read stride : 1280*2
- vsize:1280*2
- write hsize : 480 / read hszie : 240
- read stride : 1280*2*2
=> video fsync (s2mm tuser option)
=> when system booted, sdk vdma set and vdmas doesn't stop
=> sorry, I can't understand what you want exactly
 => No, I don't have the fcn
Hi @jinhanharu,
Sam
Visitor jinhanharu
Hi @samk
Thank you for your kind answer
I think your help is useful and I'll try and feed back
thank you again
