Vivado 2017.1 crash with IP CSI-2 RX, TX and DSI
Hi all,
I am trying to evaluate the MIPI CSI-2 cores on my KC705 but opening the IP from the IP catalog fro customization make Vivado crash completely. There is a similar post on this forum from a user with the same problem and it was resolved using a file sent by Xilinx. So, if any Xilinx guy is actually reading this, how could I have access to this file?
We are planning on using the IP on a future UltraScale+ custom product so any quick help would be great.
JB
Scholar austin
Re: Vivado 2017.1 crash with IP CSI-2 RX, TX and DSI
JB,
I have notified the moderator to look into this for you (I do not have the answer),
Austin Lesea
Principal Engineer
Xilinx San Jose
Thank you very much!
I attached the crash log file of Vivado in case that helps.
Please contact your FAE to file a Service Request: https://www.xilinx.com/about/contact/authorized-distributors.html
Refer this post as well
https://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-2017-1-crashes/td-p/766344
Thanks and Regards
Balkrishan
Ok, thanks for replying. I will contact my local FAE and see if it solve the issue. I looked into the AR 55854 but I found nothing obvious from the different log files besides the fact it seems to be Java related. I did some updates and cleaning reagrding Java on my system but it still crashes.
JB
