What's the output format of ctrlsw_decoder on zcu106 board
I have a h264 encoded file which format is 4:2:2 10bit
Then use ctrlsw_decoder to decode this file and stored in a output.yuv file:
   ctrlsw_decode  -i  4k_input.h264 -out output.yuv -avc --prealloc-args 3840x2160:progr:422:10:11:52
Next I encode the output.yuv file using:
 gst-launch-1.0 filesrc location="4k_input.yuv"  !  videoparse  format=nv16-le32 width=3840 height=2160 framerate=50/1  !  omxh264enc ! filesink location="output.h264"
but unfortunately,  the output.h264 cannot be decoded rightly in the PC.
Tags (2)
Re: What's the output format of ctrlsw_decoder on zcu106 board
HI @gefei-liuqi,
It should be a kind of RAW YUV data. I believe it should be the same way as it should be in memory. To read it with a PC, the best way might be a test editor.
Florent
HI @gefei-liuqi,
Do you have any update on this?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
