YUV Interleaved to semi-planar conversion IP
Does anybody know if there's any IP that allows to convert a YUV Interleaved stream to, for instance semi-planar format NV16?
Re: YUV Interleaved to semi-planar conversion IP
Hello @jlesquer ,
I hope the Frame Buffer Write and Read IP might be suitable for your case. Bascically The Frame Buffer IP's, support reading and writing a variety of video formats (RGB, YUV 4:4:4, YUV 4:2:2, YUV 4:2:0, and Luma only). The data is packed/unpacked based on the video format. Planar and semi-planar memory formats are available for YUV 4:2:2 and YUV 4:2:0.
The Supported Video formats list and those details are explained in the PG278. I hope it helps for your case.
Best Regards,
Ashok.
Hello @jlesquer ,
Best Regards,
Ashok.
Hi @ashokkum ,
Thanks for the answer, I'll have a look to the frame buffers IPs.
