ZCU102, Zynq MPSoC DisplayPort clocking
trying again with more specific problem, ZCU102 TRD uses si570 as DP clock in devicetree, this clock is not used in hardware but it can not be removed from devicetree, so what is the solution?
if we wand the si570 to be use for other clock then DP, how should we then decribe Xilinx DP DRM in devicetree?
DP itself works, both in 1 lane and 2 lane configurations, pretty cool
Re: ZCU102, Zynq MPSoC DisplayPort clocking
problem identified workaround implemented.
waiting for the FIX, 2016.3 ? or 2016.4 well need wait and hope..
Partially solved, we have succesfully removed si570 entry from devicetree and still have picture on DisplayPort monitor
