ZCU106 TRD - Adding audio functionality
I went through UG1250 and found that it covers all possible video-related use cases. I want to also add audio functionality - recording, playback and ethernet streaming of audio alongside video.
Are gstreamer mux pipelines with both audio and video supported? Is there any document/webpage detailing this?
Re: ZCU106 TRD - Adding audio functionality
Hi @rajatrao,
You should be able to do audio.
For documentation, you can look directly into gstreamer documentation
Florent
Hi @rajatrao,
Florent
Hi @rajatrao,
Was my reply enough for you? If yes, please kindly mark it as accepted solution (click on acctept as solution below the reply while logged in) to close the topic.
Thanks and Regards,
Florent
