Visitor merlyn
Zynq MPSoC Displayport Lane Reversal
Is it possible to recover in software from reversing display port lane order? I have a prototype board where displayport connector lanes 0-3 are wired to GTR TX lanes 3-0 respectively. I'm looking at UG1085 pg 926 Fig 33-1 and it seems to imply that only lanes 0,1 are to be used. Thanks.
Re: Zynq MPSoC Displayport Lane Reversal
Hi @watari,
I believe @merlyn is talking about the DP controller from the PS as he is talking about the PS GTR and pointing to the UG1085.
@merlyn,
As @watari correctly pointed, the harden Displayport controller of the ZynqUS+ devices is using only 2 lanes. This is the reason why it can only go up to 4K@30 and not 4K@60.
However, if you look at UG1085 (table 29-1) it might be confusing as you can see 4 lanes with DP:DP.JPG
 However, you can see that there is 2 times DP.0 and 2 times DP.1. This only means that there is 2 different position the 2 lanes can have. And you can see the same when configuring the ZynqMP in vivado:DP2.JPG
I do not think this is possible to swap the lanes with the DP controller, however, if you check the Zynq configuration GUI it seems that the lane are in an inverted order:
So according to your description, it seems that you are correctly connected (just set lane selection to Dual Higher). Only note that you can only use 2 lanes
Hope that helps,
Scholar watari
Hi @merlyn
I'm little confused. Because of Zynq MPSoC can implement/use at least two DisplayPort Tx.
There are DisplayPort Tx with PS-GTR (2 lanes) and DisplayPort Tx with PL-GTx (ex. 4 lanes).
In this case, it seems that you implement DisplayPort Tx at PL. So, maybe, you can change it by using remapper.
Hi @watari,
@merlyn,
Hope that helps,
