Participant p.nejad
Re: axi4s_to_video_out won't lock
Hello gentelmen,
I do have video out in slave mode with vtg_ce connected to VTC.
I looked at eol as watari suggested and confirmed that eol happens at the end of every line with blanking not just the active video. I don't know why this is happening.
Scholar watari
Hi @p.nejad
I'm not sure. But I guess your setting on vtc by software or the behavior of AFIFO are wrong.
For example, if you set wrong horizontal active width on some IP by software, these IPs behave to output wrong eol.
Because of eol signal is generally generated by horizontal active width.
The best way to resolve this issue is to set correct parameters on v_tc by software (Plan A) or to generate correct HSYNC/VSYNC/Active data/HBLANK/VBLANK into video-in_axi4s. (Plan B)
[Plan A]
I think that it's reasonable way. But it is little difficult to set correct parameter on v_tc.
[Plan B]
I'm worried about backpressure capability issue on AFIFO. It's same opinion as @bwiec.
If you can fix this issue, it's very reasonable way for you.
Hi @p.nejad,
Any updates on this?
If everything is clear for you, please kindly close the topic by marking a reply as accepted solution.
Thanks and Regards,
Participant p.nejad
Thanks for following up!!
I'm still working on it , nothing has changed yet.
