color format of HDMI Rx IP
HEllo,
how to find color format of HDMI Rx IP. to send the type of color format in AXI stream.
Re: color format of HDMI Rx IP
@xudyes it is the case right now.  So just the UART interface addresses could tell the color format. counting the frame size using tuser is done.
Thank you.
Prasanna Kumar
Scholar watari
Hi @daram123
Would you use InfoFrames which is called "AVI (Auxiliary Video Information)" ?
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/v_hdmi_common/src/xv_hdmic.c
@watariAuxiliary Video Information Info Frame is in AXI Lite, how to bring it the AXI stream..??
regards,
Prasanna Daram
Scholar watari
Hi @daram123
Do you mean that your design automatically use infoframe without microblaze ?
@watariFrom the MicroBlaze the registers data for video format have to  travel AXIStream, for dataType Selection,
regards,
Prasanna Daram
@daram123
It depends on the HDMI Source that drives to HDMI RX IP, as long as EDID in HDMI Rx supports it, the color format can be detected.  If you follow chapter 5 of PG236, run example design, type "i"menu, it tells you the color format and all other color information for the incoming stream.
HI @daram123,
Do you have any updates on this? Was @xud's reply enough for you?
Thanks and Regards,
@xud  I want in the Programmabale Logic not in the form of UART interface,,i need write in a logic based on the source the HDMI RX IP detects the color format.
REgards,
PRasanna Daram
@daram123
For Video resolution, you can figure out the active frame size by counting tuser(start of frame) and tlast(end of the line). For the color format, I don't think you can use PL to detect all the video source. Unless your source sends the pure color, and then you can judge it based on the tdata values
Thank you.
Prasanna Kumar
