display an image on monitor through without fmc card on zynq zc702
Hello are there any tutorials for display an input image on monitor  only with the help of zc702. thanks in advance
Re: display an image on monitor through without fmc card on zynq zc702
Hi @sagar8446,
I don't have enough information to answer your question, and we are deviating from the original post.
Please post your question about the resolution error to the Video forum and for the USB and Ethernet issues, please post to the Linux forum as this sounds like a Linux Issue.
When posting to the forums, please include:
  • What you are trying to do.
  • What you have tried so far.
  • Errors and statuses you have gotten.
  • Any other information about your design that would be helpful for someone to assist you.
Reposting your question will increase how many people see your issue and may help solve it faster.
Sam
Xilinx Video Design Hub
Hi @sagar8446,
The ZC702 has an HDMI interface that does not require an FMC card. Check out XAPP1205. XAPP1205 uses the onboard HDMI video display interface. I believe the ZC702 TRD may also use the HDMI interface.
A good place to find information like this is the Video Page in the Documentation Navigator Design Hub View.
-Sam
Thanks for doc. I'm running the petlinux on zc702 through sd card. But when I'm running run_video.sh command, its showing an error that input resolution is not supported....aborted. Although my screen resolution is 1366x768.Even i have the problem with the mounting of usb and ethernet. could you please help me with these problems. Thanks in advance.
Hi @sagar8446,
Sam
I want an input image to be stored in DDR3 and should be displayed through HDMI. This is what i'm trying to implement. Any reference deisgn or any help to start with this issue. Thanks in advance.
