Visitor sandyhelton
dppt.c replacement for dprx subsystem
I am upgrading our previous design which used an example design for DisplayPort (dppt.c) that seems to no longer be available. What is a suitable starting point to replace the earlier example design with one from the current dprxss_v5_0 driver? I think the original dppt.c was for a complete DP TX/RX subsystem and we had modified it for just the DP RX, since our design does not need the TX part.
Re: dppt.c replacement for dprx subsystem
HI @sandyhelton,
The new top-level software application is included in each of the example designs. For the KC705 example, this will be the xdptxss_kc705.c Ignore the TX as this is a passthrough design and includes both the TX and RX.
You can use this application as an example and then add/remove things to or from your system.
**As a general rule with the subsystems, you should only need to work with functions in the *ss* files.
Sam
Xilinx Video Design Hub
Hi @sandyhelton,
I do not recommend using the drivers/example design from the old IP with the new IP.
Several years ago we upgraded the IP from the DisplayPort v7.0 to full RX/TX subsystems.
Currently, for DisplayPort 1.2, these are:
DisplayPort RX Subsystem V2.1 (PG233)
DisplayPort TX SubSystem V2.1 (PG199)
The Displayport v7.0 IP was discontinued in 2017. (PG064)
For upgrading your design from the non-subsystem to the subsystem, I would take a look at the RX SubSystem and its provided example in PG233. (This includes the drivers as well.) I would then replace your older IP with the newer subsystem and use the example design as a guide to implementing the subsystem. When doing so, make sure to use the drivers and example that matches the hardware/Vivado version. Mixing drivers and hardware may cause issues with the driver/hardware.
Here are the available example designs:
2018-12-13 11_07_33-Xilinx Documentation Navigator 2017.2 - file____C__Users_samk_Documents_XilinxDo.png
Sam
Visitor sandyhelton
Sam,
Thank you for getting back to me. I have already done exactly as you describe. I have built the pass through design as per PG233 and the only work that remains is the application software that runs on the MicroBlaze. In the older system, there was a top level software application named dppt.c that setup the hardware and enabled DP_RX to begin negotiation. I am looking for a replacement for that top level software. The top level software uses the drivers that are imported from the hardware design, so I believe that all of the drivers correctly reflect the new block design. I am just looking for an application to replace dppt.c that initializes the hardware and helps manage the connection. Does such a top level application exist in the current example design or am I left with the task of writing it from scratch?
HI @sandyhelton,
Sam
