Visitor fengye0321
inaccurate text display on OSD
I'm using zynq-7000 and adding a OSD 6.0 IP in my project. There are two layers: one is video layer, the other is GC layer. Both are 1920 x 1080. The video output itself looks fine, just the text outputs are inaccurate as the appendix show.
What's the possible cause of this problem?
Re: inaccurate text display on OSD
Did you check the debugging section of pg019 and what is the inaccuracy you are pointing in the attachment?
Satish
Visitor fengye0321
Thank you for your reply.
If you enlarge the image, you will find the edge of text is not in order.
Visitor benvario
I have exactly the same problem. Does someone has the solution to this problem?
Thanks for your support.
Br,
Ben
Voyager
Voyager
Hi @fengye0321,
did you solve your problem? Maybe this can be usefull.
https://forums.xilinx.com/t5/Video/Video-On-Screen-Display-OSD-IP-shift-text-to-left-when/m-p/876354#M21157
I'm working with vivado 2018.2 and IP OSD version 6. I can draw boxes but I can't write text. I don't understand my mistake but I think that IP OSD is buggy. You configured OSD using API or directly writing in the registers? Have you a working design with OSD that you could share? Thank you.
Visitor danieltang
hello ,I'm working with vivado 2017.4 and IP OSD version 6. Could you a working design with OSD that you could share,like draw a box or text? Thank you.
