Observer ivanfan
mipi CSI-2 RX ZCU104
I am working with MIPI CSI-2 RX IP. I want to migrate the CSI-2 RX subsystem example design to my ZCU104 FPGA board.
From the schematic of the ZCU104 FPGA board and LI-IMX274MIPI-FMC,  the FMC Pins of MIPI are at
MIPIC => F17
MIPID0 => L15
MIPID1 => H18
MIPID2 => E18
MIPID3 => J16
However, when i fix the configuration of the CSI-2 RX subsystem, another two ports are automatically generated.
We can get the information about these new ports in PG232.
It says that these ports must be connected. But PG232 does not mention how to do it. If these ports stay connected, implementation would encount error as follow.
Phase 1 Placer Initialization
Phase 1.1 Placer Initialization Netlist Sorting
Netlist sorting complete. Time (s): cpu = 00:00:00 ; elapsed = 00:00:00.089 . Memory (MB): peak = 6348.590 ; gain = 0.000
Phase 1.1 Placer Initialization Netlist Sorting | Checksum: 72bab399
Time (s): cpu = 00:00:00 ; elapsed = 00:00:00.156 . Memory (MB): peak = 6348.590 ; gain = 0.000
Netlist sorting complete. Time (s): cpu = 00:00:00 ; elapsed = 00:00:00.091 . Memory (MB): peak = 6348.590 ; gain = 0.000
Phase 1.2 IO Placement/ Clock Placement/ Build Placer Device
ERROR: [Place 30-687] Expected cell design_1_i/mipi_csi2_rx_subsystem_0/inst/phy/inst/inst/bd_bf15_phy_0_rx_support_i/slave_rx.bd_bf15_phy_0_rx_hssio_i/inst/top_inst/bs_top_inst/u_rx_bs/RX_BS[13].rx_bitslice_if_bs be placed along with its associated I/O. Please check if the cell is properly connected to any I/O. Please also check to make sure any BITSLICE in native mode has location constraints.
ERROR: [Place 30-687] Expected cell design_1_i/mipi_csi2_rx_subsystem_0/inst/phy/inst/inst/bd_bf15_phy_0_rx_support_i/slave_rx.bd_bf15_phy_0_rx_hssio_i/inst/top_inst/bs_top_inst/u_rx_bs/RX_BS[39].rx_bitslice_if_bs be placed along with its associated I/O. Please check if the cell is properly connected to any I/O. Please also check to make sure any BITSLICE in native mode has location constraints.
Phase 1.2 IO Placement/ Clock Placement/ Build Placer Device | Checksum: 5cb32c20
Time (s): cpu = 00:00:01 ; elapsed = 00:00:02 . Memory (MB): peak = 6348.590 ; gain = 0.000
Phase 1 Placer Initialization | Checksum: 5cb32c20
ERROR: [Place 30-99] Placer failed with error: 'Placer initialization failed'
Please review all ERROR, CRITICAL WARNING, and WARNING messages during placement to understand the cause for failure.
Ending Placer Task | Checksum: 2968bdaa
INFO: [Common 17-83] Releasing license: Implementation
238 Infos, 92 Warnings, 7 Critical Warnings and 4 Errors encountered.
place_design failed
ERROR: [Common 17-69] Command failed: Placer could not place all instances
INFO: [Common 17-206] Exiting Vivado at Thu Aug  1 20:37:58 2019...
Tags (2)
Re: mipi CSI-2 RX ZCU104
Hello @ivanfan
You do not need to drive bg*_pin*_nc pins in your RTL design. Leave it as is.
bg*_pin*_nc appears on your IP , because you do not assignment MIPI pins to continuous pins.
Hope this helps
Leo
Observer ivanfan
@karnanl
Thank you very much for your timely help. If this is not the reason, then how can I fix the error I encountered in implementation? The log was displayed as follow:
Starting Placer Task
INFO: [Place 30-611] Multithreading enabled for place_design using a maximum of 2 CPUs
place_design failed
Hello @ivanfan
Could you please share your MIPI CSI-2 RX XCI file ?
I will try to re-produce this implementation error.
Leo
Observer ivanfan
@karnanl
Thank you in advance.
Hello Ivan @ivanfan
Thank you for sharing your XCI file.
I will try to test it today.
Leo
Hello Ivan @ivanfan
Thank you for your feedback.
1. Critical warnings in the red-box are reproducible.
    These critical warnings are produced by MIPI DSI TX. It can be safely ignored. Please expect the fix on Vivado 2019.2 or later.
2. Critical warnings in the green-box are also reproducible.
    These critical warnings are produced by HDMI TX IP (since 2018.3 ?!).
    Please ignore for now, fix are scheduled in 2019.2 or later.
3. Orange boxes.
    Unfortunately I cannot reproduce the issue on my side.
    I believe you set incorrect pin assignment on MIPI CSI-2 RX.
    Firstly, could you please try use ZCU102 as a project board ?
    Please try to generate the MIPI Example Design targeting ZCU102.
    After you can confirm that everything are okay. You can change the MIPI D-PHY XDC manually to fit your ZCU104 board connectivity.
The XDC file are something like this:
./design_1_mipi_csi2_rx_subsystem_0_0_ex/design_1_mipi_csi2_rx_subsystem_0_0_ex.srcs/sources_1/bd/design_1/ip/design_1_mipi_csi2_rx_subsystem_0_1/bd_0/ip/ip_2/ip_0/bd_***_phy_0_hssio_rx.xd
Leo
Hi @ivanfan
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Aoife
Observer ivanfan
Hello @karnanl
Thank you so much for your help and detailed answer.
Unfortunately, I only have the zcu104 board on hand, and there is no ZCU102 board. I looked at the block design of the zcu104 base trd and found that the two pins are connected to D16 and L20. I made the corresponding changes in my csi project, and passed the synthesis without errors.
But I encountered another problem while downloading the program. I follow the steps of pg232 to download the program using tcl and get the following results.
I followed the tutorial searched online to modify the psu_init file and still encountered the same problem.
Hello Ivan,
Thank you for debugging this.
Yes, have to assigned the bg_pin_nc pins on your device.
Probably this Forum post will helps you on (Mask poll failed at ADDRESS: 0xFD4023E4 MASK: 0x00000010)
Perhaps GTR configuration is not correct.
https://forums.xilinx.com/t5/Embedded-Boot-and-Configuration/Mask-poll-failed-at-ADDRESS-0xFD4023E4-MASK-0x00000010/td-p/941804
If this is not helps, suggest you to post a new question in
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/bd-p/EMBEDDED
https://forums.xilinx.com/t5/Embedded-Boot-and-Configuration/bd-p/EmbBoot
Thanks & regards
Leo
