mipi CSI-2 RX, no frame received
We have a system as follows: sensor -> serdes -> ISP -> FPGA( mipi CSI-2 RX -> FramebufferWrite -> PS).
We know the CSI-2 stream generated from ISP has the following properties:
  • video format: 1920x1280, 50Hz
  • color space: RGB888
  • linerate: 1.5Gbps
  • 4 lanes
  • non-continuous clock mode
  • only use virtual channel 0
So in Vivado we configured the mipi CSI-2 RX IP as: 1500Mbps, RGB888, 4 lanes. We use 200MHz as video_aclk.
However, when using baremetal software to test the video, we are getting a lot of error interrupts from the CSI-2 receiver:
+===> Other Errors detected.
Stop Error
+===> DPHY Level Error detected.
Start of Transmission Error
+===> Packet Level Error detected.
VC3 Frame Sync Error
VC2 Frame Sync Error
VC1 Frame Sync Error
2 bit ECC Error
There is no frame received event detected. We used a systme ILA to check the output of CSI-2 RX,  but it shows there is no active axi stream generated.
Anyone knows where the problem could be? (we are using Vivado 2018.3, processor is zu5ev)
Re: mipi CSI-2 RX, no frame received
Hello @xinyiz
1. Is it UltraScale+ device (I believe so) , or is it 7-series ?
2. Could you please share MIPI CSI-2 RX register dump ?
    # and MIPI D-PHY register dump if this is also accessible ?
3. I am suspecting this is Signal-Integrity problem since Interupt register mentioned:
        2 bit ECC Error
    Could you please share your Oscilloscope capture of your clock and data lane during LP --> HS transition ?
Thanks & regards
Leo
Hi @xinyiz,
Is everything clear for you on this topic?
If this is not solved/answered, please reply to the thread giving more information on your current status.
Thanks and Regards,
Xilinx Video Design Hub
