Visitor behzad34
system generator MATLAB configuration
Hello
I am working with XSG. Once XSG is installed it is configured with MATLAB and the XSG blocks were imported in MATLAB library. Now, I have developed my model and it works well without any error. However, after a while it seems that system generator configuration is gone and when I want to open system generator from the start menu a window is opened which says MATLAB is "not configured".
Can anybody help me how to configure System generator with MATLAB.
Thanks a lot.
Re: system generator MATLAB configuration
Which verison of Sysgen and Matlab is this?
The general way to configure Sysgen with Matlab is to run Sysgen xxxx.xx Matlab Configurator Window.
Have you done the same way and still see "not configured" error?
If yes right click n Matlab and select "run as administrator" and repeat the configuration.
Hope this helps.
Vanitha.
Hope this helps.
Vanitha.
Visitor behzad34
thanks. matlab is configured when I logged in as the administrator.
Newbie kluxy
Hi, I tried the 'system generator matlab configuration' but it ended up with 'Couldn't write information to .minstall file'. I use the ISE13.4 and matlab R2012a under WinXP pc. I think there wouldn't be an issue of administrator authorization under XP unlike win7 or above.
Therefore, do you have any idea what / where .minstall file exist? Thanks a lot.
