v2018.3 VCU TRD : HDMI Rx not working on ZCU106
Hi All,
I have been successfully acquiring video on the hdmi port and displaying on an hdmi monitor using the attached config file "hdmi_config_file.png".
I then started playing around with GST_TRACERS in an attempt to measure latency. At some point I tried to stop an hdmi capture pipeline using Ctrl + C but the pipeline wouldn't stop. I then used Ctrl + Z, followed by kill -9 to terminate the pipeline. From then onwards, I cannot run any pipeline involving hdmi rx.
1. Running vcu_gst_app with the attached config file produces the error:
Error!! code "Could not read from resource." to pipeline [1]
2. Running the pipeline: GST_DEBUG=v4l2*:7,v4l2bufferpool:7, gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! video/x-raw,width=1920,height=1080,format=NV12 ! queue max-size-bytes=0 ! kmssink bus-id=a0070000.v_mix produces the logs captured in the attached file "hdmi_log.txt"
This issue is a bit similar to this one. However, my current issue doesn't go away with a reboot.
My hdmi rx is connected to the  hdmi output port of a Raspberry-pi.
Thanks for  helping.
Scholar watari
Re: v2018.3 VCU TRD : HDMI Rx not working on ZCU106
Hi jmfiri@lanterneng.com
As you mentioned before, the input resolution is 1920x1080. But current setting on /dev/media7 is different it.
So. I guess it seems a route cause.
Would you modify it, when it occur same issue ?
Scholar watari
Would you execute the following commands to find a route cause ?
$ cat /sys/devices/platform/amba_pl@0/<your hdmi rx ss>/hdmi_info
$ xmedial-ctl -p -d /dev/media0
@watari Thanks for the direction.
1. The command: cat /sys/devices/platform/amba_pl@0/<your hdmi rx ss>/hdmi_info produces the result shown in the attached hdmi_info.png. Here i see a "No input stream detected" and a "DVI" mode but i'm not sure how to proceed from there.
2. The command: xmedia-ctl -p -d /dev/media0 produces the output shown in the attached medi_info.png.
Thanks once again for this and any further help.
Scholar watari
Would you make sure number of /dev/video and /dev/media by the following command, too ?
$ ls /dev/video*
$ ls /dev/media*
Also, would you share your HDMI source device name, too ?
@watari  Thanks,
The video* and media* lists are in the attached video_and_media.png.
HDMI device name is /dev/video0.
Scholar watari
Would you make sure correct number (ID) of media bus by using "xmedia-ctl -p -d /dev/mediaX" ?
I guess, at least, /dev/media0 is wrong media bus in this case.
Find message of /dev/video0 in the result of xmedia-ctl.
@watariThanks,
The media bus for /dev/video0 is media7. I can't seem to identify the issue, please see attached scrren shot.
Scholar watari
See if this Wiki Page is of any help:
Zynq UltraScale+ MPSoC VCU TRD - Debugging - HDMI Rx Capture Pipeline
Chris
Video Design Hub | Embedded SW Support
@watariThanks, that's correct. I figured out I had somehow editted/uncommented the hdmi_mode in my /boot/config.txt of the raspberry pi to hdmi_mode=4, which made the Raspbery-pi to output 1280x720 resolution. I think somehow the HDMI Rx pipeline autodetected this resolution and enforced it. Yet in all my test application, I was using a capsfilter with 1920x1080p, hence the error.
After changing the hdmi_mode on Pi back to 1080p, I ran vcu_gst-app (out of curiosity) and that changed the HDMI Rx settings (screen shot attached) and successfully executed. I'm sure I could also have changed the setting's manually (screen shot attached) as mentioned on the wiki pointed to by @chrisar
Thank's a lot. I'm going to accept @watari 's answer as solution since he/she has been on the line helping for a long time, and kudo's @chrisar 's answer.
@watariNice work and thanks for helping jmfiri@lanterneng.com find the problem!
jmfiri@lanterneng.comyou are right the HDMI will lock on what ever the input resolution is.  You could then use the scaler to resize the video, but your app would need to do that.  I don't think that the vcu_gst_app does this, but you could do it manually by using media-ctl.
Chris
