Observer zineb
vga controller
hi community, i'm a bigenner in the world of fpga. so i used vivado to design my architecture but unfortubately i'm needing to use a vga controller. so my question is there any IP that play the role of a vga controller in vivado?
thank you for replying as soon as possible
warm regards
Re: vga controller
Hi @zineb,
You can do a VGA controller using 2 Xilinx IPs:
-> AXI4S to Video Out and Video Timing controller
To generate the video stream you can start with the Test Pattern Generator.
Also, if you want to start slowly, you might want to check this tutorial.
Hope that helps,
Re: vga controller
@zineb,
Here's an example VGA controller I've used in the past.  The project also contains a Verilator based simulator, that will display on your computer monitor even before you place your project onto the FPGA to work with it.
Dan
Observer zineb
Re: vga controller
@dgisselq
first thanks for replying, is it an example or what, please how does it work?
Observer zineb
Re: vga controller
@dgisselq i was talking about finding an IP in the Vivado tool that can be a vga controller!!
Re: vga controller
Xilinx Doesn't have any IP for VGA controller.
You can find list of Video IPs in the IP catalog
This document may help you for VGA interface design
http://ece-research.unm.edu/jimp/vhdl_fpgas/slides/VGA.pdf
Thanks and Regards
Balkrishan
Re: vga controller
Hi @zineb,
Hope that helps,
