video deinterlacer
I'm trying to implement the de-interlacer as per the diagram on page 23 of the video in to AXI4-Stream product guide.  The fid output of the video in to AXI4 is suppose to be connected to the de-interlacer.  Its not clear from the de-interlacer product guide which pin should be used for the fid input. Please advise.
Re: video deinterlacer
the deinterlacer only supports RGB, YUV422 or 444. If you've got the 'Video in to AXI4' set to mono/senor format you can't connect it to the the de-interlacer. I get the error
ERROR: [xilinx.com:ip:v_deinterlacer:4.0-100] /zed_hdmi_display/v_deinterlacer_0 Propagated type xilinx.com:video:Y_400:1.0 is not supported
I'll assume  that its not possible which is a shame.
The Video Deinterlacer does not have a FID (Field ID) input.  It assumes that the first field is always zero.  There is a register that can be flipped to switch the order.  You may also want to review the Release Notes Answer Record for the Video Deinterlacer as it has information that supplements the Product Guide on working with specific situations.
Chris
Video Design Hub | Embedded SW Support
Visitor gnleaf
Can you tell us exactly how to configure Video deinterlacer?
thanks,
gnleaf
