[vivado 2018.3 ]HDMI tx interrupt problem
I used vivado 2018.2 to generate kc705-HDMI example on our customized board and it worked fine. However, I upgraded vivado 2018.2 to 2018.3 and found that HDMI TX interrupt didn't trigger immediately at every bootup.
After around 30 seconds, it triggered and displayed to the monitor.
I also used vivado 2018.3 to generate HDMI example, the problem still happened.
How can I solve this problem?
BR,
Sitting
Re: [vivado 2018.3 ]HDMI tx interrupt problem
Hi @sitting
If you are okay to use 2018.2, can you close this thread, please? This issue is planed to be fixed in the next release of Vivado
Hi @sitting
The clock of HDMI TX is generated from Video PHY, so you need to check the Video PHY TX Ready and LInk Ready before you can get the HDMI TX interrupt
Hi @xud,
I need to revise my description that HDMI TX interrupt should change to HDMI TX HPD interrupt.
Why TX HPD event(TxConnectCallback function) didn't trigger immediately with 2018.3?
I am curious why there is an issue with 2018.3, but no issue with 2018.2.
Sitting
Hi @sitting
This is feature enhancement for HPD in 2018.3 HDMI TX. TX Connect Event should happen when HPD pulse is longer than 100 ms, which aligns with HDMI spec.
 Hi @xud,
I think our customized board has no problem, because we have passed hdmi certification.
I will try to borrow HDMI FMC and KC705 to test this problem.
Sitting
Hi @xud,
I have tested 2018.3 HDMI example design with kc705 and HDMI FMC card, it has same TX HPD issue. Microblaze need  around 30 seconds to execute TX HPD interrupt function and displayed to the monitor.
Can you help to check this issue?
BR,
Sitting
okay @sitting
Can you attach xci file and let me know the sink type pleases?
Please also let me know how you measure the interrupt time. I will do some test at my end, and then get back to you.
Hi @xud,
Attached file are my xci file(phy/tx/rx), and my sink is Dell UP3216Q and HP z27s.
I measure the time between cable insertion and TxConnectCallback function execution.
BR,
Sitting
@sitting
I have done some tests on KC705 board and UP3216Q.  It was very slow at the first time. I had to press "c" to force it to colorBAR mode.
After I unplug, and plug the TX cable back, and ensure it's solidly connected. I couldn't reproduce the problem anymore. ColorBAR can show up on the screen ~5 seconds.
I'm attaching the terminal log for your reference. If you see the issue, please press "z" and "i" from the menu, we can get more clue on that.
Hi @xud,
Your result was same with me. It always happened at the first time when you booted up. Is any method to fix it? I think it is not a normal behavior.
BR,
Sitting
@sitting
I only saw this problem when TX cable was a bit loosen. After I confirm the TX cable is tightly connected to HDMI port, I couldn't reproduce the issue any more.
If you can still reproduce it, please provide the log file.
Hi @xud,
You mean that you can't reproduce issue at the first cable insertion of each boot up, right?
If so, I will provide my test log and experimental procedure tomorrow.
BR,
Sitting
Hi @xud,
Attached files are my logs. Here are my test procedures:
1.Boot up KC705 (or Program FPGA)
2.Plug Tx Cable tightly
3. Wait a few seconds and press "z" & "i" to show the log
4. Wait a long time and show color bar on the UP3216Q
5. Unplug and Plug cable
6. Show color bar on the UP3216Q around 3 seconds.
I repeat these procedures and always happen the problem at  the first time.
I also do AB test between 2018.2 and 2018.3.
There is no problem on 2018.2 and procedures are become :
3. Show color bar on the UP3216Q around 3 seconds.
4. Unplug and Plug cable
5. Show color bar on the UP3216Q around 3 seconds.
BR,
Sitting
@sitting
Thanks a lot for your detailed steps.  I will try to power up the board before plugging the TX cable.
Also I can confirm I have seen the same message, when trying to force the colorBAR.
From your log file, it seems that clock is still 0. Can you dump all the Video PHY register value, please?
Hi @xud,
How do I dump all the Video PHY register value? Can you teach me?
BR,
Sitting
@sitting
I was able to reproduce the problem just now. No need to get Video PHY register dump from you.
I will file a change request to report this problem, and debug further at my end
@sitting
I have created CR to report this issue two weeks ago. Our HDMI engineers are looking into it.
Can you let me know if you are okay to use 2018.2 version at the moment or it's very critial to you.
Hi @xud,
Yes, I can use 2018.2 version and also look forward to the solution.
BR,
Sitting
Hi @sitting
