where can I find 'MIPI DSI RX Subsystem'?
I use zu102 development board, and I use vivado 2017.4, only find ‘MIPI DSI TX Subsystem’, where can I find 'MIPI DSI RX Subsystem'?
Re: where can I find 'MIPI DSI RX Subsystem'?
Hi @luoyanghero ,
You might want to contatc our partner NorthWest Logic, they have a solution for DSI RX. Refer to this page.
Hello @luoyanghero
MIPI DSI is intended for Display interfacing. That is why we don't have RX sub-system IP for MIPI DSI.
We only have MIPI DSI TX IP available which supports Display serial itnerface MIPI protocol.
For RX purposes we have CSI RX MIPI IP which stands for camera serial interface protocol.
Please refer PG232 for more help on this.
Thank You
Hello @luoyanghero
Hope you get to see my response. Please conclude this post by accepting the solution.
If you have any further questions around MIPI IPs Please start a new thread.
Thank You
Hi @luoyanghero ,
>Does ‘DSI RX Subsystem’IP included in vivado 2019.1?
No.
As @kvasantr , @florentw   already clarified. We do not have DSI RX subsystem IP.
No plan/schedule to support this on future Vivado.
@florentw Thanks a lot. Does "DSI RX Subsystem" IP included in vivado 2019.1?
@florentw I use vivado2018.3. How can I apply for this IP trial and use it in vivado 2018.3?
