Observer bva_rzn
write buffer number vdma
Hi.
I understand with genlock the synchronization of the vdma module.
The vdma settings are shown in the figure. 3 buffers are selected.
The video format is 1024x768.
Correctly I understood the documentation on axi_vdma. After the user pulse in the input video stream, s2mm_frame_ptr_out shows the frame number to which the frame will be recorded.
Connected ILA, the trigger starts the record by the value uset = 1. In ILA it is shown that after the user's pulse in the input video stream s2mm_frame_ptr_out for 520 cycles shows 7, and then 6.
The question is, what kind of number will the input frame be written to?
Thank you.
Re: write buffer number vdma
Hi @bva_rzn,
To close the topic, please kindly click on accept as solution on the best reply.
Best Regards,
Hi @bva_rzn,
Could you show the ILAs for s2mm_frame_ptr_in and s2mm_frame_ptr_out?
Hi @bva_rzn,
If everything is clear for you on this subject, please kindly mark a reply as solution to close the topic. Else please reply to the topic
Thanks and Regards,
Observer bva_rzn
I'm sorry for the delay.
I decided the question.
Topic can be closed.
Hi @bva_rzn,
Best Regards,
