Observer ain0102
zedboard fmc tutorial not working
Hello.
I play tutorial with zedboard and FMC-hdmi modules.
Tutorial is a Vivado 2013 version, and it created a bit file with the version 2017.4.
Link : http://zedboard.org/sites/default/files/design/FMC_IMAGEON_2013_3_IP_Tutorials_20140320%281%29.zip
I created bitstream file by applying the option and also compiled the sample code.
option:  tcl.pre setting
set_property SEVERITY {Warning} [get_drc_checks NSTD-1]
set_property SEVERITY {Warning} [get_drc_checks UCIO-1]
However, the screen does not output through hdmi out port.
I don't know what to check.
Help me do something.
Tags (2)
Scholar dpaul24
Re: zedboard fmc tutorial not working
@ain0102,
This was the answer --> Put an ILA core to monitor the Video dma (o/p side) signals as it has failed.
Prerequisite is that you must understand block level functionality of the design you are implementing.
Please let me know if there are any examples I can refer to.
This is like a s/w oscilloscope. You attach the signals to the ILA inputs and you observe their behavior when your trigger condition is met.
https://www.xilinx.com/support/documentation/ip_documentation/ila/v6_2/pg172-ila.pdf
FPGA enthusiast!
All PMs will be ignored
Scholar dpaul24
Try to see if those signals are being properly driven/have the correct values.
FPGA enthusiast!
Observer ain0102
Thank you for your answer.
Where should I add the ILA core?
Thank you.
Scholar dpaul24
@ain0102,
FPGA enthusiast!
Hi @ain0102,
Is everything clear for you? If yes could you kinldly close the topic by marking the best reply as the accepted solution.
If not, please reply with your current status.
Sam
Xilinx Video Design Hub
Observer ain0102
Here I attach a file that works with the version of vivado 2017.4 I modified.
With this file, I succeeded in the test.
I hope it helps everyone.
The usage of the file is :
Create a project in vivado 2017.4 and enter the source ./[TCL FILE] command in the tcl console.
