BUFG in cascading DCMs
Here is the figure from the Virtex-II Pro User Guide. I always believed that the idea of clock tree, the net driven by BUFG, is equalize the clock delays to all the FF. This is also known as clock skew minimization between regs. Now, I see that BUFG is used to drive the only one "flip-flop", the second DCM. What is the need to use the low skew? Which skew is minimized?
Instructor
Instructor
Re: BUFG in cascading DCMs
First, you need to know that the routing between DCM's, IBUFG's, and BUFG's is all high-speed
dedicated routing with very low skew and prop delay.  The only time you get in trouble in V2
is when you use components on opposite edges of the chip.  If your input pad (and IBUFG),
DCM, and BUFG's are all on the top edge, for example, then the routing delays will match
well enough to avoid hold time issues.  The clock trees themselves (shown in the simplified
block diagrams as a single BUFG and a large fanout net) have significant delay, several
nanoseconds in V2, but also match eachother quite well.  You should really run some test designs
through the tools and look at the delays in the timing reports to see how this works.
So given the low skew, low prop delay routing between clock components, but the much
larger (but again low skew) prop delay of the BUFG's you can see why inserting the
BUFG to match the one in the feedback path is necessary to maintain low skew at
the output.
As for 180 degree clocks and clock duty cycle, the DCM by default creates a clock output
with 50% duty cycle.  You can turn off the duty cycle correction using one of the attributes,
but generally you shouldn't need to unless you use both edges of the input clock externally.
In the normal, duty cycle corrected case I find that the usefulness of the 180 degree clock
is limited because its rising edge is coincident with the falling edge of 0 degree clock,
and almost all clocked structures in the V2 have the ability to use falling edge clock
without imposing additional delay.  Further, the case made for driving DDR outputs using
180 clocks vs. both edges of CLK0 doesn't hold water in my view, since the clock tree
rising to falling differential skew is on the same order as clock tree to clock tree skew.
Also the dual clock tree approach uses twice the routing reources at the IOB's and
often leads to unroutable designs if you don't take this into account before selecting
a pinout.
Just my 2 cents,
Gabor
-- Gabor
Teacher rcingham
Does it break the design when you do it like the diagram tells you to?
The figure you have pasted here is just to show how to cascade DCMs. It just uses shift register to for cascading.
I see that people prefere stupid rules and unnecessary overcompications/waste to the extent that they draw in empty talk those who try to optimize/understand the good design.
Scholar austin
v,
The BUFG resource is used because the clock signal will always arrive before a data signal.  The clock tree is faster, by design, than any/all possible interconnect.  So, it is important that the clock signal arrives everywhere it is needed, before the data has changed on another element on the same clock domain, a BUFG is used.
This is called proper synchronous design.  In an ASIC the clock tree is often the trickiest part to add, after the logic is synthesized.  In the FPGA, we do that hard work for you, in advance, by designing a general purpose clock tree that can reach every element with gauranteed timing behavior.
BUFG's are also matched resources:  they all behave identically, within 100ps of one another.  So using the BUFG in the feedback path for Clkinfb (the feedback pin) aligns the output of the BUFG within 100 ps of the Clkin.
Since in this example, we are concerned with the locked out of the DCM which is operating in its clock domain, and the reset in of the second DCM is operating in its clock domain (I presume the Clock outputs are different frequencies, or phases, as if they were the same, then there is no reason to cascade), the DFF is used to synchronize the LOCKED output to the RESET input of the second stage.  The BUFG is needed on the second DCM for the feedback, and the BUFG is needed on the first DCM for the feedback AND to capture the LOCKED signal properly.
If you don't care about the phase relationship of a DCM output, you may drive the Clkin from a regular interconnect (no IBUFG is required, unless you are trying to match the incoming phase with the outgoing phase of te DCM).
But, if you use the outputs, at all, from a DCM, the use of a BUFG for every output used means that clocks will always get where they need to go at the right time.
Using regular interconnect for clocks is just wrong, and the tools don't support it:  do not do it.
You may skip use of the IBUFG if you don't care about phase in == phase out.
Warnings will tell you you did not use an optimal path, but if that is OK, ignore that warning,
Austin Lesea
Principal Engineer
Xilinx San Jose
Thanks, There are lots of BUFGs in the figure. And, you have explained all of them besides the one I wanted. Do you see the one that connects DCM1 DV_out to DCM2 in? That is the major cascading line - we take the clock generated by first DCM to another. What is the need for BUFG inbetween? Keeping two domains "in-phase"?
BTW, Xilinx provides BUFG to keep regs in-phase. But, DCM is allowed to produce shifted phases. How do you keep the difference? You definitely need to use another BUFG for another phase. That is another clock tree with arbitrary skew from the first!
Scholar austin
v,
The one from CLKDV can be left out, as it really doesn't matter that the phase and delay is unknown (unconstrained). This will mean that the clock out off the second DCM will not be aligned in phase on any input clock edge, and that the delay from a clock edge is unknown. Using that BUFG means that depending on the D value, and M/D of the second DCM, some output clock edges would be aligned exactly with the input clock to the first DCM )+/- 200 ps, as each stage is +/- 100ps).
If you are synchronizing between the two clock domains (from DCM 1, and from DCM2), the BUFG insures you avoid really bad states where metastability is likely, as opposed to places where metastability is less likely.
Austin Lesea
Principal Engineer
Xilinx San Jose
Instructor
Instructor
Just to clarify Austin's remark, the BUFG in question matches the delay on the BUFG in the
feedback path of the first DCM.  On the output of the DCM, CLK0 and CLKDV are aligned
on the rising edges of CLKDV, at least for integer divide ratios.  The BUFG in the feedback
path adds a delay to the CLK0 output which is then subtracted out because the input phase
comparitor is on the output side of this BUFG.  So the output of the BUFG on CLKDV will line
up with the input clock rising edges.  You can leave it out if you don't need this alignment,
for example if the external clock is just an oscillator and not connected to any external
devices that communicate with the FPGA.  However note that leaving it out will result in
an effective negative delay of one BUFG prop delay from the input clock to the output.
You could theoretically leave out both BUFG's and get the same results, but I think in
Virtex 2 you need the one in the feedback path for routability.  Newer devices like Virtex 5
have internal feedback in the DCM.  You can certainly try to remove the feedback BUFG,
and the tools will let you know if the result is not routable.
-- Gabor
-- Gabor
> So the output of the BUFG on CLKDV will line up with the input clock rising edges.
It is interesting to know - why? I understand that DCM might be good aligning all its outputs, putting them in one phase (and shift 90, 180 and 270 properly). However, I do not understand why you are sure that passing these parallel outputs through independent BUFG instances still keeps them in phase? The DCM-BUFG traces may vary in length. The clock trees produced by BUFG might also be different. I see that to match BUFG output rising edges with ones at DCM input, the following is proposed in the same document
You see: the same BUFG drives the (not shown) flip-flops and the feedback. This ensures that all clock consumers are "in phase" with the input clock. Clocking another DCM with a similar single BUFG at the output, I could have another clock tree in phase with the first one. However, a different BUFG is used in cascading example. The phase with DCM1 input clock is lost, IMO. This makes the BUFG between two DCMs useless. I do not see what could keep the phases together when fanout branches are driven through the different BUFGs.
The same problem I see in BUFGing different phases. For instance, take
This makes CLOCK switching simultaneously with its inverse. But, what about the duty cycle? How much phase 180 is away from 0?
Instructor
Instructor
the output.
a pinout.
Just my 2 cents,
Gabor
-- Gabor
Gabor, It was a good explanation
Teacher eteam00
Unpaid commercial advertisement on behalf of the forum admins:
  • If your question or topic has been fully addressed, please mark the single keenest posting in the thread -- the one post most closely representing a solution -- as the 'solution'.  This will also mark the thread as 'solved'.
  • If you are impressed by the wit or wisdom imparted in any posts (other than your own), feel free to 'reward' or compliment the post's author with a 'kudo' (click on the star near the left margin).  You can kudo many posts, not just one.  And you don't have to be the thread's 'owner' to add your own kudos (compliments) to posts which are worthy.
Thanks!
-- Bob Elkind
SIGNATURE:
Summary:
